Its like crack. Lots of people are scared, then there are those that have to flash daily, or even hourly
Lol yes it is like crack... first your afraid to do it, then you dabble and you kind of like it and you wouldn't mind doing more to see what else you can get out of it... then eventually you start looking for reasons to keep flashing stuff and might even blow off work or other things to stay home and flash stuff on your phone........... just like crack
Owning this particular phone with the massive amount of stuff to flash after only a couple weeks makes me a happy camper.
Sent from my Galaxy Nexus
If for no other reason...Adfree
Diminishing returns relative to opportunity costs? Are you an econ major? For those that flash like crack there is not much we could be doing that is "better" unless it involves a new way to flash or new stuff to flash. Sometimes the search for new crack is half the fun. Don't worry so much about what others might think of your obsession, you'll know when its to much.
Frequent flashing is not for just programmers. There is NO programming with flashing. As an example I just flashed aokp build 12 to gain a mod that removes the clock from notification bar. I started the download at home and went to the mall with my gf to shop. After 45 minutes it was done downloading and I flashed it in JCPenny. I didn't wipe, just dirty flashed it and profit with no programming.
You don't need to spend a lot of time doing it, just move it into the "background" of your life. Constant multitasking, especially if you have a girlfriend/wife.
I'm not concerned what others think nor am I an econ major, more concerned about spending time on something that is not a top priority. I think your right that we all find the right balance through experience.
I have a question? I didn't wanna make a separate thread about this but for those rooted with a 4.0.3 ROM, does it improve the camera?
- Use of screen capture apps.
