Re: [Automated] Wug's Galaxy Nexus Root Toolkit v1.2 (Updated 1/1
Guys
I don't see the Android SDK drivers installed in my C drive. I guess I have to use this option but don't know how to use it. There's no button in the rootkit GUI to do so
Use the "SDK + Files" option first to extract the necessary files to their proper locations
I thought I updated the OP to remove that. My fault. The latest version, (v1.3) no longer needs the SDK. All the files the program needs extract to the local directory where the program installs too. All you need to do now is configure the drivers.. and it actually will do that automatically.
The SDK+Files has been removed, because lots of people were forgetting to do that, and I was able to accomplish everything the program does without it. adb and fastboot are included in the program. That is why the latest version has a significantly smaller file size.
Just install it. Configure drivers. And you are good to go. If you want to use adb cmds globally from cmd line manually. Use the option, "System Variables" to do that. (optional feature).
Enjoy! Let me know if you have any other questions.
{{ WugFresh }}
