greydarrah
ROMs are just a fun part of owning a Nexus, but if anyone doesn't want to mess with them, there's nothing wrong with that. What I can't understand is why anyone would unlock, root, then unroot and re-lock the phone. Being rooting has absolutely nothing to do with whether or not you are experience a stock phone. Rooted and other wise stock is EXACTLY the same as being stock and not rooted. Rooting gives you the ability to modify the phone, ONLY of you choose to do so. It's exactly the same thing as going onto Windows File Explorer and clicking on the box that says "show hidden system files." You haven't changed Windows at all, unless you decide to do something to those system files that you can now see.
I recommend making a nandroid backup of your phone after rooting and installing all your apps and setting the phone/screens up as you want them. Then, no matter how many ROMs you try, you can always go back to stock in a matter of minutes. You can even get an OTA update from there (though that might make you lose your root).
