Please help me unlock and root
llasch
182
7
So I am on a Macbook Pro and have been following the above steps in the sticky for unlocking my bootloader in an attempt to take that big boy step and root this beeotch.
When I copy the platform-tools file over into the terminal and then go on with the ./fastboot oem unlock command I get a "waiting for device" prompt and get stuck. Also, after clicking on tools-->android in my sdk folder to get the platform tools folder to appear, 'fastboot' is already a folder inside of the platform-tools folder. I have tried copying and pasting the folder with both the original fastboot in that folder as well as removing that and replacing it with the separate one I downloaded from the same site shown in the mac tutorial sticky video...both still give me the "waiting for device" prompt.
Someone please help, on top of this being my first time unlocking and rooting I also recently made the switch from PC all of my life to this being my first mac, so I'm still adjusting to that as well. Thanks in advance for your help and patience.
thebizz
phone addict
Nov 8, 2009
3,568
42
Are the drivers installed on your comp if not it won't work as your computer will never see your device
Edit seems you don't need drivers make sure debugging is checked under development options
Andrew Ruffolo
3,567
172
its waiting for your device because its not in bootloader.
You can type ./adb reboot bootloader (make sure debugging is on on the phone before or it won't work)
llasch
182
7
I am in debugging mode and it still says "device not found". Do I enter ./adb reboot bootloader before I try the unlock command?
Andrew Ruffolo
3,567
172
if the phone is booted... enter
Code:
when you see the android with open panel type:
Code:
llasch
182
7
Ok I'll try that as soon as I get out of class. Appreciate the help as this is new territory for me. I'm sure this will be the first of many 'help me' topics I start lol.
thtknt
