NotJustAPhone
Looks like Milestone 5 will be out sometime today. Of course, I just flashed build 34 yesterday so what else could I expect.
Sent from my ADR6400L using Tapatalk 2
Been waiting for this. PZ is starting to act up.
Scratch that. ITS OUT. Looks like I'll be flashing tonight. Can't wait!
I have m5 up and running and just finished setting everything up. As usual, I'm running it with LeanKernel and so far so good.
How is it without using the default kernel? My buddy told me that there is some sort of fire and brimstone "use our b/c of the new 4.0.4 patches" thing in the RW thread.
That being said, will obviously be flashing franco lol
What about the FA02 Radios. I Flashed them last. I didnt know if M5 had them.Running M5 with Franco M3 and it's running superbly . I don't even boot after flashing a ROM until I flash a Franco kernel anymore.
ROM > 20120317 gapps > Franco kernel.
Profit
Flashed M5. Very quick and smooth so far. Only think I notice is that my signal strength is way down. Where I usually have full 3G and 4G (NYC) I know I have about three bars 3G and 1-2 of 4G.
My signal has been fine. Immediately flashed franco kernel though. Not sure if faux is paying the AOKP guys, but his kernels are simply outclassed IMHO.
Where can I download the flashable zip of francos kernel? I've been wanting to try it out, might as well now
If you don't have the app, I would check his threads on XDA and RW. There should be a link there for them. I'm using Milestone 3, which IMO, is the best kernel out there right now.
Custom roms almost never come with radios included.
Whatever radio you have will persist unless you change it.
That also goes for nandroid backups - they don't save your radio versions.
?updated to IMM76I
◦differences between IMM76D and IMM76I are ALL in the Galaxy Nexus kernel
◦we updated the Galaxy Nexus kernel to Faux?s 16m kernel by default, which incorporates the fixes from IMM76I
Above quote is from the milestone 5 release. I don't claim to know anything about IMM76I mumbo but I am just wondering if flashing different kernels would muck up anything.
Some of you probably have flashed francos so the above may mean absolutely nothing.
Maybe its romans way of saying please use faux's kernel.
