[GUIDE] Don't Panic: The Hitchhiker's Guide to the Galaxy Nexus
dmmarck
Retired Moderator
Dec 28, 2011
8,349
2,594
Go to the Mac method guide. Download the 4.0.4 superuser. Zero neck posted it. Flash it in recovery.
Sent from Oliver, Destroyer of Worlds & Connoisseur of Bean-Shaped Confections
reeper55
162
4
Re: [GUIDE] Don't Panic: The Hitchhiker's Guide to the Galaxy Nex
Ok I know I sound like a maroon (this is all very new) how do I go about flashing the zip?
dmmarck
Retired Moderator
Dec 28, 2011
8,349
2,594
Download it, place on phone, reboot into clockwork recovery, install zip, find that zip on your phone, install, reboot system :)
Reactions: 2defmouze
reeper55
162
4
I don't have clockwork recovery remember, I am unable to flash it.
dmmarck
Retired Moderator
Dec 28, 2011
8,349
2,594
You're going to need to fastboot it. If I had power I'd be able to help you, but unfortunately I don't so i'm like the Lawrence of Arabia of the DC area right now...constantly moving to find the juice!
zero neck
The Ever-Living
Jan 13, 2011
3,127
1,386
You need to DL cwm touch for toro I think iTS version 5.5.04 or something.
then you put that in the adb folder that contains fast boot .exe
Put the su zip on your SD card and turn USB debugging on.
Connect tocpu with USB. Then boot phone into boot loader mode.
Next CD to your adb folder with terminal commands.
Then enter this command:
./fastboot boot nameofrecovery.img
That should work let me know if you need more help
I'm not home but I will be around five if you need clearer instructions.BTW that will boot cwm temp on your phone then you install the su zip in cwm.
reeper55
162
4
That would just be like the procedure to do the unlock right?
If so I think I can do it but i just dont know the "file name" to use.
dmmarck
Retired Moderator
Dec 28, 2011
8,349
2,594
Are you familiar with fastboot?
If so...go to clockworkmod.com (or whatever the site is; google it) and download the touch recovery for our Nexus (toro). It is 5.8.0.2.
Then, get to the bootloader (all volume + power when the phone is off) and cd to the directory the file is in and then
"fastboot flash recovery recoveryname.img"
For Ubuntu, it's simply cd'ing to the folder (like Downloads) and "sudo fastboot flash recovery recoveryname.img"
reeper55
162
4
Guys I am sorry but i am just not familiar enough with this sort of thing to follow what you are asking me to do.
I believe I am going to need a private lesson and be walked through the process. :-\
dmmarck
Retired Moderator
Dec 28, 2011
8,349
2,594
You may have to wait until I get power. My apologies. :)
If someone else wants to, please be my guest!
reeper55
162
4
If you would be willing, I would be truly grateful. No rush, I will be out this evening anyhow. GOOD LUCK getting that power back. I went 3 days without it in October when we got that huge snowstorm in Massachusetts.
dmmarck
Retired Moderator
Dec 28, 2011
8,349
2,594
I'm at my school (former) right now. If you want, I can walk you through the steps on a Mac. No idea how to fastboot crap on a Windows machine.
I prefer doing it by Gchat. Do you have that?
reeper55
162
4
I only have a windows PC, no Mac here. :mad:
reeper55
162
4
Thanks a bunch. I'll give it a try in a bit. Trying to my baby girl down for a nap.
dmmarck
Retired Moderator
Dec 28, 2011
8,349
2,594
Just make sure all of the drivers are installed and that you follow his instructions, but he should be able to make you right in a matter of seconds lol
reeper55
162
4
You were right!!!!! I am now rooted. Now i need to figure out how to get JB on there.
Thanks for the guidance sir!!
MarcosVo
