drb1089
ok i figured out the problem...my usb cable was bent so it wasnt connecting but i bent it back i got it back to stock and im about to flash bamf 2.3 at least now i know what not to do lol thanks a lot for your help
Any way to go around being rooted? And how do I get my file in my SD card so that I can get to it from the bootloader recovery menu ... I have wipe cache, wipe data, and update. On update I have 2 choice but neither have my downloaded jb rom. As a matter of fact they don't have anything on them...
This is because of the new multi-user features built into 4.2. You need to use the latest versions of TWRP or CW recoveries when flashing 4.2 ROMs to avoid this. I've heard that getting rid of the /0 folders is a real PITA too.
Good luck.
Good luck.
Keep us posted. I got rid of the multiple /0 folders and they haven't come back.
I don't see any /0 folders.
Also, if you're using Jelly Bro--make sure to change your network under Mobile Data to LTE/CDMA.
i need some help please i currently have bamf 2.3 toro and im trying to flash 2.4 toroplus but when i try to wipe data it says failed and so i wipe everything else and when i go to install 2.4 it says failed i still have 2.3 on my sd so i can reflash that and it works but i want to put 2.4 on there can anyone tell me what im doing wrong thanks.
lol thanks i didnt know it was for different carriersToroplus is the Sprint Gnex.. do not try and flash a Toroplus ROM on your Toro
