I went back to the FA02 radios, just to see whats going on.
I was randomly getting no service.(bar with an x through it. I live in a full 4g area. ). I am on aokp M5 and franco r156.Going to test it tomorrow and see if i get the same dropouts. This just started happening today. It occurred twice.
Anyone else having the same issues?
EDIT
Update, it happened when I was sending a text message. Signal dropped out and also said message not sent. So I just tried it again on the FA02 radios and it did it again when I tried to resend the message.
Wierd!
Took forever for 3g to come back?
I wonder what that is called?
When you flash radio and nothing...
Oh yeah FAIL!
No foreal what happened?
sent from a Android device
I'm always on!
Ok so I am trying to follow all the "updates" to the radios. I have Liquid 1/35 with the extras, and I flashed the radios with Baseband version I515.09V.FA02 / I515.FA02. From what I have read I need to go back to 4.02 radios and than flash the new 4.04 radios or use as I read on page 2 use DT file and it will do it all for me , downgrade to 4.02 and than upgrade to 4.04. Please advise.
Thanks,
Xanth
I just want signal at my job even with the new radio I get nothing
You don't have to roll back to 4.02. You can flash either 404 with boot loader or without, both will revert to 402 then patch to 404 FC04/5 radios.
But you may as well flash with the bootloader.
So would that be the DT File? or is there another file/link for this.
Thanks for your help,
Xanth
Sorry man you look into changing prl version?
Honestly I wouldn't even know how I just know sprint gets reception at my work and Verizon struggles
