1. craigrn16's Avatar
    Ok, so I tried to root got to the last step and the the phone rebooted and the Google screen is up. Now I know it is supposed to take a while on that screen but its been over 15 minutes. Is my phone bricked???!!
    05-25-2012 01:37 AM
  2. twindragons187's Avatar
    Nope. If u waited 5 min go ahead and do a battery pull
    2defmouze likes this.
    05-25-2012 01:38 AM
  3. craigrn16's Avatar
    ok you sure?
    05-25-2012 01:47 AM
  4. twindragons187's Avatar
    Yep. Its really hard to brick a nexus
    05-25-2012 02:03 AM
  5. twindragons187's Avatar
    Did it work?
    05-25-2012 02:46 AM
  6. craigrn16's Avatar
    Did it work?
    Yup thanks man. I was worried. Now I gotta find that 4.0.4 ota
    dmmarck likes this.
    05-25-2012 02:49 AM
  7. twindragons187's Avatar
    What one? The newest one?
    05-25-2012 03:22 AM
  8. 2defmouze's Avatar
    This.
    OP.. The number 1 rule is Don't Panic. This phone is unbrickable for all intents and purposes as long as your not a maniac. If you run into trouble just come to the forums let us know what's up and someone here will help you.
    Also, don't go through all the trouble to just to run some boring stock ROM. Flash aokp and see what your phone can do. Follow instructions and you'll be fine. Also see Zero Necks RADIOS thread to update your radios very easily.
    dmmarck and DB12088 like this.
    05-25-2012 05:14 AM
