[ROM] Android Open Kang Project- Jelly Bean Style
jova33
357
3
Neither do I lol. I just know what I hear. Like people have been saying the x governors are choppy. Interactivex, hotplugx, and so on.
Sent from my wireless telephonic device.
MRW1215
798
15
So, is there anything I should be aware of, by setting mine to "ondemand"? What does that mean for my phone, and what is the difference between using "ondemand" or "interactive"? Is there some sort of noticeable difference at all?
anthony1117
98
Enjoying this ROM a lot. Found few bugs, my clock in the right crner and th one at the top of my pull down do not auto matically update the time.....Kinda confusing and frustrating,. Does anybody else have this problem or is it just me. SHould i try a reset and reinstall? Any suggestins would be awesome.
Explicit
297
18
Mine changes perfectly. Try a full wipe and reinstall :confused:
Jubakuba
123
Set your governor to anything but interactive.
And then look at a logcat.
Your phone will be crying about input boost endlessly.
The interactive governor is specifically tailored and the roms are specifically tailored to work with it.
The primary change would be this "input boost" that is supposed to ramp up your CPU to 700mhz+ the second your screen is touched.
2defmouze
3,945
1,552
Getting a lot of system UI crashes. Anyone else? Also pretty bad battery life. With M1 and Franco M6. This is on full clean wipe.
Did you restore system data?
And by clean wipe you mean you:
Wiped data/factory reset
wipe caches
wiped system
(overkill maybe, but the wipe data/factory reset is the important one) ?
Xanth269
511
26
wipe caches
wiped system
I did a dirty to M1 and Franco M6, no issues, and battery life is a little better but not great, had better battery life when I was using JB ports (Jakeday).
dc5_alex
20
wipe caches
wiped system
Nope didn't restore system data. And yes I wiped all those other things. Might re-flash with clean install again tonight and see how it goes -_-
ottscay
1,010
67
For what it's worth, I flashed the new 4.2 GAPPs zip (after making a backup naturally) and have had no problems so far, so it looks like AOKP JB 1 works fine with it.
MRW1215
798
15
So, since 4.2 is still Jellybean, is AOKP just going to go to build 6 when they update to 4.2? Or will they go back to "build 1"?
SeigaGen
678
95
I believe they will continue with build 6.
Brought to you by the Google Galaxy Nexus.
Hit me up at the Android Developers Conference from December 4-7 in San Francisco.
ShinyTop
667
63
Is there a reason that AOKP has not been updating. When I click on the link to AOKP news is the OP of this thread my browser, Chrome, informs me that site is infected with malware. Can we expect this situation to be fixed soon. I was used to seeing many posts a day in this thread but now it goes days with no posts.
jova33
357
3
It took them a couple of weeks before they put out anything after jelly bean source was released. They're working on it, just be patient. :)
Xanth269
511
26
The one I have noticed about AOKP is it may take a little longer than most others but they usually release a bug free ROM. I'll wait too see what they release. Jakeday would be a back up if AOKP fails yo deliver any thing new.
Xanth269
511
26
noticed that too no matter what browser I choose. Hope it some sort of web hosting issue.
bdGDL08
94
9
The aokp site was hacked so they took it offline for a bit. It will be back up soon, but everything is still available on Androtransfer.
Drew
akbarramadhani12
