oxymoron
It's been real...
There's really no need to wait for a milestone build. The euroskank AOKP kangs are my daily drivers. Totally stable. I have no issues at all.
Totally agree. Been loving steve spears aokp linaro builds (used a bunch of dizzy's and skanks regular aokp compiled builds too with great results). That said, I'm curious as to why there isn't more "official" builds across the board at this point. 4.2.x has been out for a while now.
Has anyone tried out both the DizzyThermal builds and the Euroskank builds? If so, is there any noticeable difference at all?
What gapps did you use?
Anyone test out 4.2 yet?
So I updated TWRP Recovery, wiped dalvik/cache/system, then flashed AOKP 4.2.1, then the new gapps, then a tibu zip. Wiped dalvik/cache after each flash. Great. But instead of having to restore the tibu backups and nova settings, everything was in place just as I left it before the new ROM was flashed, as if I did a dirty flash.
OK less work but it seems like I did something wrong.
Any ideas ?
AOKP Backup thinks I am not on an AOKP ROM now btw.
I'm using CWM 6.0.2.3. Is there any need to switch to TWRP before flashing to 4.2.1?
If you didn't wipe data then you did a dirty flash, that's why all your apps are still there and settings. Also wiping cache/dalvik between flashing those items is redundant, you don't need to at all. Thirdly, I'm pretty sure Roman hasn't updated the AOKP backup app yet for the new builds, which would explain why it doesn't recognize the ROM.
