jmorosky
Sorry I switched to mmuzzy french vanilla...
I'm giving PA a go now. I was on CM for a bit too.
Sent from my Galaxy Nexus using Tapatalk 4 Beta
Keyboard Issue:Man, ribbons are pretty cool! I set up my left swipe ribbon to have my favorite most used apps, and I set up my right swipe ribbon to have direct dial (or long press to text message) buttons for my most contacted, er, contacts. At first, I was having issues with the drag handles pulling out when I was using the keyboard, but the options in the settings let me position the drag handles at the perfect place so as not to conflict with the keyboard. I like it!
Just out of curiosity, though, how do you make the other ribbons activate, if you have them turned on? I mean, things like swipe left/ right/ bottom/ top are pretty easy to figure out (just swipe from the specified area of the screen), but what is the lockscreen ribbon, notification ribbon, toggle ribbon, etc.? If you enable them, how do you pull them out?
When I first flashed it, it was working pretty great. For whatever reason, though, lately I've been experiencing a lot of lag and slow down in Chrome. Weird that this is just happening now, considering I haven't flashed or installed anything new since.
Ok so its been awhile since I flashed , was running Build 5, than I flashed the July 27 nightly and than a newer nightly was released, is it OK to dirty flash between nightlies?
