Color Controls in CM10
jmiesse134
129
9
Ok so I want to get the same look I had with the trinity kernel
My color multipliers
R145
G135
B200
What settings should I use in CM 10 since they use a different format?
dmmarck
Retired Moderator
Dec 28, 2011
8,349
2,594
R145
G135
B200
I use CM sett. for the gamma then use those multipliers. It gets close. I suggest starting with the CM sett. setting in gamma and going from there.
jmiesse134
129
9
I guess what I meant was the cm10 kernel doesnt have the same format as the trinity app.
Trinity has the format I put above but cm10 has this
R 0.xxxxxxxxxxxx for example.
So I was looking for the a conversion chart or something
In other words .. What value =135 and so forth
dmmarck
Retired Moderator
Dec 28, 2011
8,349
2,594
I know that ;). Start with the preset settings--CM sett for the gamma, and then start tinkering from there. For me, an avowed lover of trinity's colors, I usually just keep it on that and leave everything else alone lol
