07-24-2017 05:21 PM
47 12
tools
  1. egamerhdk's Avatar
    What does that mean? Sorry, I'm still not good with the jargon.
    09-20-2012 02:57 PM
  2. dmmarck's Avatar
    Turn your device off. Hold down volume up, volume down, and power simultaneously until it vibrates. What happens?
    Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
    09-20-2012 03:28 PM
  3. egamerhdk's Avatar
    It take me to an open Android with a start button. I can cycle between power, restart bootloader, recovery mode, and power off.
    09-20-2012 04:08 PM
  4. dmmarck's Avatar
    Brilliant. And your goal is to go back to stock, correct?
    EDIT: NM, I forgot your USB is busted, ignore me. My apologies
    09-20-2012 04:11 PM
  5. egamerhdk's Avatar
    Yes, back to stock. Apparently Mobile Odin will help me do that with the tar image I have, but so far, I'm not able to get it to work.
    As a note: when I go into recovery mode, it takes me to the Google Logo. Been stuck there for about 10 minutes.
    Am I running Mobile ODIN wrong?
    All I do is load the tar and hit flash. Am I supposed to do something when the phone is starting up?
    EDIT: Should I extract the tar?
    Also, when I use mobile odin, and click flash, it restarts and does something really quick, then the phone starts up into cm9 and goes "Android is upgradeing your apps"
    09-20-2012 04:14 PM
  6. egamerhdk's Avatar
    Bump with Video of it in action
    09-20-2012 08:14 PM
  7. egamerhdk's Avatar
    Does anyone know of another signed tar file I can try?
    09-21-2012 11:35 AM
  8. Jubakuba's Avatar
    I don't know man.
    I'm sorry =/
    09-21-2012 12:29 PM
  9. egamerhdk's Avatar
    Two things I can do I think:
    1. I bought mobile odin, you think maybe I should try the free version?
    2. Flash some kind of stock on it. I just don't want the CM9 logo to appear on bootup. I think they'll definitely charge me if they see it.
    09-21-2012 12:32 PM
  10. Jubakuba's Avatar
    Get cwm back.
    Use ROM manager.
    Then follow this post and the post above it.
    xda-developers - View Single Post - Back to stock recovery with broken USB port!
    Make share to replace the files.
    At school...but that seems to be what you want.
    09-21-2012 12:59 PM
  11. egamerhdk's Avatar
    I'm already lost at the first step... how do I get CWM back?
    09-21-2012 05:01 PM
  12. dmmarck's Avatar
    Download ROM Manager. Use ROM Manager to flash it.
    09-21-2012 05:02 PM
  13. egamerhdk's Avatar
    Okay, I think I understand all of the "jargon" now.
    I have all of this:
    Radio: CWM-flashable
    Bootlaoder: CWM-flashable
    Recovery
    ROM: Stock
    Which do I flash first and in which order do I go in?
    09-22-2012 08:22 PM
  14. vivek615's Avatar
    You know... in fastboot you start with the bootloader then the radio then the ROM...
    However I think you should try in the order recommended in the xda post
    Did you insert the system.img into the zip file on xda?
    EDIT: Wait isn't that post for the GSM Nexus?
    Do not flash any GSM nexus files they will hurt!
    09-22-2012 11:47 PM
  15. egamerhdk's Avatar
    I only read the instructions. I noticed it was GSM.
    Also, if I flash a new recovery before rom... won't that disable me from flashing a new rom?
    09-23-2012 12:47 AM
  16. Jubakuba's Avatar
    Download TORO factory images.
    Place the system in the root of the cwm.zip folder in the link I gave.
    Flash everything aside from recovery.
    The recovery should auto-flash upon booting up and erase CWM.
    09-23-2012 06:56 AM
  17. egamerhdk's Avatar
    1. Hmm... it's kinda hard to move stuff into a zip throught astro... can I just flash each item one at a time?
    2. When you say flash... do you mean in Mbile Odin or in CWM?
    3. Also, are you sure I'm safe using the cwm.zip you sent me... because it's in a GSM thread.
    09-23-2012 11:59 AM
  18. vivek615's Avatar
    Well you only want to use a toro cwm... but I think that.zip you're referring to is designed to install whichever gnex system you're restoring... so as long you put in the system.IMG from the factory image for our phones then you should be okay...
    09-27-2012 02:05 AM
  19. vivek615's Avatar
    Btw jubakuba will egamer be able to flash stock this way with bootloader locked? If you flash back to stock unrooted with an unlocked bootloader then there's no way to relock without USB because you don't have root
    http://www.galaxynexusforum.com/foru...-lte-only.html
    Flashing with cwm is easier than Odin if you have the option
    I think you should be able to use files from this thread in mobile odin but you should lock boot loader first cause I don't know if mobile Odin will
    09-27-2012 02:13 AM
  20. mhpspeed's Avatar
    Returning to Stock Without USB Access
    (This guide assume you are rooted and need to return to stock.)
    CDMA users: Mobile Odin won't flash CDMA radios. Verizon users using an unofficial radio can flash the most recent official radios from here.
    An Automated Bootloader Unlock/Relock Application can be found HERE.
    Re-lock your bootloader with that application and continue below to the ODIN portion of this guide.
    If you prefer to do this process manually:
    Install Terminal Emulator.
    Download THIS file and use a file explorer to put it on the root of your SD card (not in a folder).
    Open up Terminal Emulator and run these commands:
    Code:
    su
    (Hit Enter)
    Allow Root Access.
    Code:
    dd if=/sdcard/param.lock of=dev/block/platform/omap/omap_hsmmc.0/by-name/param
    (Hit Enter)
    This should lock your bootloader.
    SPRINT Odin Files
    VERIZON and GSM Odin Files
    Download the appropriate ODIN.tar files on your phone (PDA files only for CDMA users).
    DO NOT use odin files designed for another device.
    Download and install Mobile Odin.
    Use Mobile Odin to open the .tar file you just downloaded and return to stock.
    Congratulations!
    You should be back to stock and with a locked bootloader!
    *NOTE*
    I have not personally tested this method. I've dotted my i's and crossed my t's as far as I know.
    However, if this didn't work for you: Feel free to PM me as I have another more-complex method that I have up my sleeve.
    A few users have reported this working!
    If you're currently freaking out thinking you're even MORE stuck with a locked bootloader and your rooted system:
    Download THIS file and put it on the root of your SD card.
    Run these commands into Terminal Emulator:
    Code:
    su
    (Hit Enter)
    Allow Root Access.
    Code:
    dd if=/sdcard/param.unlock of=dev/block/platform/omap/omap_hsmmc.0/by-name/param
    (Hit Enter)
    This will unlock your bootloader again.
    A HUGE thanks to Efrant for providing the param.zip and making me aware of the existence of this possibility.
    THANKS THANKS THANKS! This works, is this part of one of the stickied guides at the top? it should be, I searched my problem (malfunctioning usb port) and found it and it worked pretty painlessly. BRAVO. Hope that other dude got it worked out.
    Jubakuba likes this.
    10-10-2012 02:16 PM
  21. Jubakuba's Avatar
    http://forums.androidcentral.com/ver...hogie-way.html
    This is linked in the hitchhikers guide that is stickied, yes.
    Glad you got it!
    10-10-2012 02:45 PM
  22. MyDroidM8's Avatar
    This is an old thread, but was hoping to get some help.
    I have an HTC one M8 and trying to return it to Stock without USB Access. I am rooted and using the Philz recovery. I am trying to LOCK the bootloader. My attempt to update the ROM fails, and from all I have read, I am missing the step to lock the bootloader.
    The links to param.zip (param.unlock and param.lock) in this post are broken. Can you help point me to param.zip?
    Appreciate a response and thanks in advance
    07-24-2017 05:21 PM
47 12
  1. Is there someone I can pay to root and jb my nexus?
    By fminusfminus in forum Verizon Galaxy Nexus Rooting, ROM's, and Hack's
    Last Post: 02-10-2014, 12:00 AM
  2. my nexus s is bricked and wont recognize the usb is plugged in
    By arrogant437 in forum Sprint Nexus S 4G Rooting, ROMs, and Hacks
    Last Post: 06-25-2013, 06:58 PM
  3. Do I need to unroot AND wipe my device for OTA updates?
    By GK3K in forum Samsung Galaxy S3
    Last Post: 07-09-2012, 06:44 PM
  4. Is there someone I can pay to root and jb my nexus?
    Last Post: 06-30-2012, 01:07 AM
  5. Google Voice and my Nexus S.
    By Pride in forum Sprint Nexus S 4G
    Last Post: 07-16-2011, 08:42 AM
