Re: [ROM] [AOSP] MMuzzy's Jelly Bean - 4.2.1 - JOP40C - New Build!
Sounds like a Verizon issue, had the same thing with my landline. I'd call them again. If you really wanted to narrow down the problem try flashing a new ROM and see if the issue persists.
Edit: Make sure your on LTE/CDMA.
I'm having a weird issue that recently came up. I'm on the newest build, but I'm not receiving any incoming calls or texts. Not using any 3rd party voicemail or text apps. I was before, but did a *73, *900, etc. I have 3 to 4 bars on both 3G and 4G. Data comes across fine.
When someone calls, there is no ring, the screen doesn't light up. nothing. then I get a voicemail alert. Texts show up after I check my voicemail. So it seems like my phone isn't grabbing a tower for purposes of receiving calls and texts. I've checked around and even called tech support at Verizon. They "fixed" the issue and it happened again the next day.
so, any suggestions on what I can do here. should I flash some new radios? I appreciate any advice.
Sent from my ASUS Transformer Pad TF300T using Tapatalk 2
