1. Snake1985's Avatar
    So I have successfully unlocked the bootloader and installed TWRP on my GNex using my Macbook Pro. Unfortunately, during the process my OS was wiped out. I am currently stuck with no OS to load. After searching thru multiple threads, it looks like I need to sideboot an OS to get the phone back working again.
    I cannot for the life of me get my mac to recognize the phone so I can run the ADB process. Can someone please assist me with this issue or shine some light on a solution? Currently 3 days with no phone and it's getting frustrating...
    12-01-2013 01:14 PM
  2. Xanth269's Avatar
    do you have access to a PC to try and see if the phone gets found?
    is the original rom file and gapps on the phone? if so try re installing that file. or did you still have factory rom?
    after that someone with more knowledge is needed, try going here:
    [ROM] [4.2.2] AOKP :: jb-mr1 :: toro - Page 454 - Device Threads - RootzWiki
    Best of luck.
    12-04-2013 06:05 AM
  1. Help! "REMOVE APPS" is using up data!
    By stefanib123 in forum Verizon Samsung Galaxy S4
    Last Post: 11-07-2016, 12:14 AM
  2. Battery Drain With Power OFF???
    By MobiFan in forum Samsung Galaxy SIII I9300
    Last Post: 12-02-2013, 11:57 PM
  3. Samsung Galaxy S4 HELP 4.4 update
    By poli881990 in forum Samsung Galaxy S4 Google Edition
    Last Post: 12-01-2013, 06:07 PM
  4. Nexus 5 in pocket with Note 3
    By Theel1 in forum Google Nexus 5
    Last Post: 12-01-2013, 04:04 PM
  5. HTCDev Help
    By Rob Herley in forum Sprint HTC One
    Last Post: 12-01-2013, 03:49 PM
