flashpiti
Isn't the Bionic getting great battery life on LTE?
I think it's better than the other LTE phones but still not great.
With a SAMOLED+ screen, 2000 mAh battery, and a more efficient processor, i see no reason why it wouldn't get 8-10 hours stock. Rooted, 12+ hours easily
The Bionic's battery is 1800 or less. The Prime's battery is gonna be at least 1800. And LED screens use MUCH less juice, especially when you have the brightness cranked all the way down because they're still very visible - much more so than an LCD screen set to the same brightness level. I have no doubts at all
your logic is flawed. even so, it would never ring true as the Prime is not getting an LED display!
Also, LED IS LCD!!!! It is identical to every other LCD you have ever seen other than it uses LED as a backlight for the LCD panel vs. CCFL backlights. LED have a brighter light, longer life, and drastically reduced footprint. hence thinner and thinner TVs.
wiki Amoled and Pentile to learn about the display tech of your new future phone
That's really splitting hairs. I can't argue with you that s/amoled is technically led. You would be the first person I have heard reference it as led! Especially in the era of LED displays, LED being LED backlit LCD. Also, prime users won't realize the power saving characteristics ibow is describing over bionic. As technically the bionic is using the more efficient version of pentile screens, RGBW. The nexus will use the less efficient RGBG version.
Do all 4LTE phones have the ability for data and voice?
Only the thunderbolt and probably the vigor can do simultaneous voice and data on 3g.. just fyi
Interesting. Do we know why that is, or how they they are doing that? I am quite curious about this and was not aware of this capability.
And I guess there is no chance of the Prime having this?It's a different network technology called SVDO
