koolbon
Re: Soft/On Screen Buttons- Whats the point?
I've been thinking the exactly same thing. I really don't see the advantage of it. The phone might look really clean and cool, but that's about what I can think of as an advantage. Those buttons will have to be there all the time to be able to function except for movies games maybe. Even then, the buttons will have to appear at some point and it's only adding more steps to do things. I thought they will at least keep the size of the phone manageable with 4.6 or whatever the screen size they are coming out with, but looking at the leaked image that's not the case either. Buttons being there all the time might even make the screen ugly being some type of mismatches with apps you are running. I am dying to see how they are covering all the aspects of these cases.
I don't understand what the big deal about wanting the buttons as part of the screen is for a phone. I understand in merging gingerbread and honeycomb, the code would have to merge the two types of buttons used, but I don't get why they need to be a part of the screen on a phone. Its not like you can ever get rid of them---you always need a home button, and you'll still need menu and back since those aren't built into any apps and google isn't going to have every developer re-write their apps. Since those buttons will always have to be there, its not like we're gaining any screen space. Also, now more of the screen needs to be lit up, which means more battery used. I think I'd prefer if the buttons stayed how they are now. Somebody explain why I should want this (not why its happening, I get the merging the 2 OS thing).
