CynicX
Re: Soft/On Screen Buttons- Whats the point?
With root the on screen buttons can be modified. However stock is so well designed rooted users generally only change the colors to match the background or whatever.
I'm genuinely confused, why are people thinking the virtual buttons will be configurable by app developers? Maybe I'm just not correctly understanding what every
one means :-\.
We already have a bar of virtual buttons in Honeycomb and the app developers can't just mess around and change it as to how they feel fit(which would be bad).
The way I see it virtual buttons simply look cool and allows the buttons to rotate with the device, that's cool and more than enough reason for me.
