It's bgr, so grain of salt required. Close to the rumors though Samsung Galaxy Nexus full specs revealed; Verizon Wireless exclusive
Android 4.0 Ice Cream Sandwich
9mm thin
4.65-inch 1280 x 720-pixel Super AMOLED HD with curved glass
TI OMAP 4460 dual-core Cortex A9 processor clocked at 1.2GHz
1GB of RAM
32GB of built-in storage
5-megapixel camera on the back, 1.3-megapixel in the front
1080p HD video capture support
LTE/HSPA depending on carrier
Wi-Fi a/b/g/n
NFC
1,750 mAh battery
1.2 ghz? Come on that makes no sense. Plus, what gpu will it have? Same mali 400 as the gs2 or what? I mean it's gonna need a very beeft gpu to power that resolution. I don't think the cpu will be running at only 1.2ghz. I envision at least 1.5ghz.
They'd be doing it to save battery life.
1st, save battery when the screen is off. underclock to 700 mhz and love it.They'd be doing it to save battery life.
1.2 ghz? Come on that makes no sense. Plus, what gpu will it have? Same mali 400 as the gs2 or what? I mean it's gonna need a very beefy gpu to power that resolution. I don't think the cpu will be running at only 1.2ghz. I envision at least 1.5ghz.
No surprises if this pans out. I'm sure even if the processor were the TI 4430 clocked at 1.2 Ghz, it would still be plenty fast. I don't understand the fuss over processor speed, but then again I don't really do anything on my phone that requires that much power outside maybe playing HD videos.
Really, I also wouldn't be getting this mainly for the specs (which are better than anything on Verizon right now). I would be getting it for the Nexus stock experience.
Here is another EXCLUSIVE that BGR had a couple of days ago
iPhone 5 -- Sprint scores exclusive thanks to $20 billion deal with Apple?
Time to get out your salt shakers gentlemen/ladies.
