Okay, things are becoming messy quite fast as I'm sure those observing the rumor mill probably expected this.
According to Droid Life, there will be 2 versions of this phone. So...here are the spec lists of each phone.
Info pulled from Droid Life.
Galaxy Nexus (Exclusive for Verizon)
Release: October of this year
Part Number: SCH-I515 (LTE Version)
Android 4.0 Ice Cream Sandwich
9mm thin
4.65-inch 1280 x 720-pixel Super AMOLED HD with curved glass
TI OMAP 4460 dual-core Cortex A9 processor clocked at 1.2GHz
1GB of RAM
32GB of built-in storage
5-megapixel camera on the back, 1.3-megapixel in the front
1080p HD video capture support
LTE/HSPA depending on carrier
Wi-Fi a/b/g/n
NFC
1,750 mAh battery
Nexus Prime (for everyone, but Verizon)
Release: Early next year (Maybe even earlier given it has just passed through the FCC) See "Edit 5" down below.
Part Number: GT-I9250 (GSM Version)
*******now get ready for this...*******
9mm thin
***Samsung Exynos processor clocked at 1.5Ghz
***PowerVR SGX543MP2 GPU (same as the iPad 2 and iPhone 4S)
1GB of RAM
***8-megapixel camera on the back, 1.3-megapixel in the front
Wi-Fi a/b/g/n
NFC
***2,050 mAh battery
First of all....none of this is official and all rumored. They say these specs are coming from anonymous inside tipsters. Take with a big chunk of salt.
Second, I don't know about you, but if those specs turn our legit for the non-Verizon (the Nexus Prime)....well...I will be very disappointed.
Too good to be true? Probably....maybe...?
Nonetheless, I made this new thread to help consolidate all the specs running around. I will edit this first post as I refresh the usual Android sites. Also, because I'm bored.
Sources:
Possible “Nexus Prime” Specs Sneak Out This Afternoon, This Isn’t the Galaxy Nexus (Updated) - Droid Life: A Droid Community Blog
Samsung Galaxy Nexus Details Leak: Fully Stock Experience and a Verizon Exclusive - Droid Life: A Droid Community Blog
EDIT: I think the first set of specs are quite underwhelming. I also think the 2nd row of specs are much more deserving of a killer (Prime) phone. We know the Exynos 1.5ghz chip was just announced so the possibility of that even existing in a Verizon Nexus phone is slim considering a release date of October. The whole 5MP vs. 8MP camera is again, arguable...I know early rumors pointed to a 5MP camera with improved low light sensors which would make a big different for sure. So either way, 5MP or 8MP it shouldn't really matter. Battery life...the 1750 sound realistic and the 2050 just sounds like wishful thinking. I can only see such a battery being in this phone if the battery was non-removable.
All rumors pointed to a true Google Experience, Nexus phone coming to Verizon, why on Earth it would be called a Galaxy Nexus and NOT a Nexus Prime is beyond me....and why Verizon would get the short end of the stick specs wise is again, pretty lame. Why they can't just make one badass phone, I have no idea.
Let's debate!
EDIT 2: If there are 2 versions of this phone, it would make sense that the Exynos goes in the other non-verizon units as it doesn't support Verizon's LTE service. That would mean TI OMAP for Verizon and Exynos for non LTE carriers (everybody else). So...this could be legit. A LTE version for Verizon with OK specs....and non-LTE version for everyone else...making up for the lack of LTE with super beefy specs
EDIT 3: So, here's another set of specs...no idea for what carrier this would be, but maybe these are universal specs. Not as detailed as the other spec lists but yea...here you go:
Display: 4.65-inch HD(1280x720) Super AMOLED
Camera: 8 megapixel (flash)/2 megapixel on the front
Battery: 1850 mAh
Value added features: 1.5GHz dual core AP, embedded 16GB memory,
Bluetooth 3.0 HS, WiFi a/b/g/n
Source: General ***Official Nexus Prime Specifications, Speculations and Rumors thread*** (specs/pix 10/6)) - Page 65 - Android Forums
EDIT 4: Even more random specs showing up. Over from the XDA Developer forums someone provides these specs from the "prototype" model. (THANKS user: Phantomash)
1.1280?720 pixels / 4.65" / 315ppi
2.16GB internal storage and 1GB RAM (micro sd extension no supported)
3.The prototype unit was running a dual-core cpu at 1.2....no info if it was the new exynos but he thinks production model will be clocked at 1.5Ghrz like galaxy S2 (the prototype of galaxys2 was running a 1Ghrz CPU)
4. 5MP back campera and 1.3 in front
5.Ice Cream Sandwich is very similar to honeycomb.
6.No metal back cover but instead a plastic one in champagne colour and a little rough like GS2.
7.No info about battery capacity cause they haven't decided yet...
8.Vodafone exclusive in Europe with a November launch...
9.Samsung Galaxy Nexus is the official Name.
Again, unconfirmed stuff, but I thought I'd post it in here anyways.
Linky: http://forum.xda-developers.com/showthread.php?t=1293124
EDIT 5: ALSO, it would appear that Part Number: GT-I9250 has just passed through the FCC with ATT radio frequencies. This device features NO LTE. (THANKS users: Boondoc for the heads up and Scottatron for the links!)
So I suppose there will be 2 versions of this phone...that is of course if the GT-I9250 is indeed a Nexus or a similar phone with slightly different changes and without the Nexus title. Maybe this phone will have the Exynos 1.5Ghz CPU in it, something that Droid Life hinted at. See the original post way above for the supposed specs of the GT-I9250.
Links for proof: Samsung Nexus Prime (GT-I9250) Passes Through FCC With AT&T/World Bands
https://fjallfoss.fcc.gov/oetcf/eas/reports/ViewExhibitReport.cfm?mode=Exhibits&RequestTimeout=500&calledFromFrame=N&application_id=150400&fcc_id=%27A3LGTI9250
I really hope we don't get a weaker version than whatever the GT-I9250 will be. That would be disappointing.
Anyone have any ideas or opinions on what GT-I9250 might actually be if it's not a Nexus phone or rehashed version of what Verizon is getting?
My hope is that it's just the same hardware but with different radios in it....LTE vs. GSM.
9mm thin
1GB of RAM
Wi-Fi a/b/g/n
NFC
1,750 mAh battery
9mm thin
1GB of RAM
Wi-Fi a/b/g/n
NFC
Sources:
Let's debate!
Battery: 1850 mAh
