1. ace0187420's Avatar
    I am wondering if anyone knows how the sound of the phone is as it pertains to music and headphones? I listen to music while working and its loud where I work so high volume is needed.
    10-30-2011 11:37 AM
  2. wyseguy77's Avatar
    I'm sure it will be better than the Fascinate. At least it better be.
    Sent from my SCH-I500 using Tapatalk
    10-30-2011 11:42 AM
  3. infernalman7's Avatar
    Yeah, I'd want to know more about the loudspeaker actually. I thought the iPhone 4 one was bad but after changing to HTC Sensation, the iPhone's was much better IMO.
    Hopefully the loudspeaker on the GN will be great. I remember before the iPhone days, many phones have real awesome speakers. (Nokia N95 for example)
    10-30-2011 12:06 PM
  4. edgefever's Avatar
    My bolt has great sound on the speaker. Hope it's as good.
    10-30-2011 12:09 PM
  5. ace0187420's Avatar
    I hope its loud all around good speakers and good through headphones.
    10-30-2011 12:21 PM
  6. milkshed27's Avatar
    Do you own or have you considered in ear monitors? They can be a bit uncomfortable if you've never used them before but you get used to them. Different brands and models vary in sound isolation. Since these headphones will block out ambient noise from your workplace you will be able to play your music at a lower volume and also save your hearing.
    10-30-2011 03:43 PM
  7. wheezy276's Avatar
    I too am most curious about the loudspeaker volume/quality..
    Every time I crank my OG droid up folks always say "wow that's louder than my phone", which are usually HTCs or iToys..
    10-30-2011 04:33 PM
  8. ace0187420's Avatar
    Yeah I have noise canceling headphones sennheisers but the source of the music still matters and the htc phone I have not good for it.
    10-30-2011 05:36 PM
  9. milkshed27's Avatar
    What are the ohms on those Sennheisers? For portable devices the lower the ohms the better. The lower they are the easier the phone will be able to drive the headphones. But too low will blow the circuitry. 16 ohms is recommended as the lowest level. If those Sennheisers are say 32 ohms the volume they will produce will be lower than if you used headphones that were 16 ohms.
    Another option is try using an app from the market that can boost the output or gain. Do a search in the market for volume boost and you'll get some results. Volume Booster worked for me for a while. An app called Equalizer is one that I use for bass boost but you can also raise the gain level.
    10-30-2011 06:02 PM
  10. blackmannx#AC's Avatar
    sound is quite nice.. very loud but does get a bit distorted when cranky up really loud. I do prefer the HTC BEATS integration but with all the apps out there that do great audio processing headphone listening sounds amazing..
    whartpence likes this.
    10-30-2011 06:05 PM
  11. milkshed27's Avatar
    So the Beats integration actually does improve audio quality on the phone?
    10-30-2011 06:14 PM
  12. ace0187420's Avatar
    They are 16 ohms I will check out some of the apps you mentioned.
    10-30-2011 06:59 PM
  13. humpagardengnome's Avatar
    Any sound has gotta be better than the muffled cries for help that are emitted from the T-bolt.
    10-31-2011 02:57 AM
  14. Andrew Ruffolo's Avatar
    Srsly... I got a jambox for work
    humpagardengnome likes this.
    10-31-2011 03:46 AM
  15. ace0187420's Avatar
    So does beats really help with the music Quality? Or is it just the headphones?
    11-04-2011 05:50 AM
  16. qnet's Avatar
    I downloaded poweramp from the market for my xoom and, it's very nice. I found out about it after researching beats audio on the rezound. A article I read said that poweramp would do everything htc beats would do because it has a eq.
    I admit, poweramp is a very nice app and, I will use it on the GN if, the default music app is not good enough. It's probably the best audio app I've had.
    11-04-2011 07:44 AM
  17. jamesbrown33's Avatar
    I love poweramp's audio quality, I really hope that once google music comes out of beta google releases an api for 3rd party apps to take advantage of right now I use poweramp for all the music I can fit onto my device and google music for the rest, but I'd prefer to use poweramp for everything
    11-04-2011 08:18 AM
