Preach2k
I have a question. This will be my first Nexus Phone. Can you use a Micro SD reader with the Galaxy Nexus?
I think you meant to say 8GB internal.
Actually, that nets about 6.5GB available internal storage, and it seems to be dedicated just to apps. I've never found a way to put any of my own data into that area, so my user storage area consists of my uSD card capacity. Have you been able to put anything into your internal memory, except for apps?
Sent from my Transformer TF101 using Tapatalk
Yea, sorry. I was confusing that with the 16gb micro it shipped with. The 8gb internal is just for apps.
Sent from my DROIDX using Tapatalk
So without an SD card how will we be able to restore CWM backups? Sorry if this is a silly question, but I've always had phones with SD cards so when I make a backup in CWM, they live on the SD card so when I install a new ROM or something and need to go back I can just use the backup on the SD card. If there is no SD card, then won't my backup get erased when I wipe the whole phone before installing the new ROM?
Or do I have to backup in CWM, then transfer the backup to my computer, and then if I need it, then transfer it back to the internal memory and restore
Click to view quoted image
Works fine on my transformerProbably not without root. I haven't tried it in a while but it didn't work with HC....using a mouse and keyboard works but not storage...
