I have a Cisco E4200 Wireless N Router downstairs, which provides great speed with my Galaxy Nexus. My bedroom is at the other corner of the house, and the signal has poor penetration there. Our house also has poor 3G/4G reception, and in fact, we have to use the Network Extender to get call reliability. So I need to get a better Wireless signal up there.
So, I just bought and installed the Netgear AV200 Powerline Wireless N Extender - the 'base' unit connects to the router downstairs via ethernet, and plugs into a wall socket. The Wireless adapter plugs into a socket in our bedroom, and is able to access the network via powerlines, and generates a strong Wireless N signal.
The problem relates to SSID, signal stength, etc.
Initially, I set up the Netgear adapter to use the same SSID and passphrase as the Cisco Router. Using WiFi analyzer, I can see this signal and it's strong. But my GNexus doesn't connect to it, but remains connected to the 2.4GHz signal coming from downstairs, even though it is much weaker.
I then created a different SSID for the Netgear Wireless Adapter, and a corresponding new WiFi connection on my phone, and it connects fine and gets great signal. But it doesn't seem to want to switch from the weaker downstairs signal, to the stronger upstairs signal, when I go upstairs. I have to manually switch.
So:
Is there any way to configure things to use the same SSID, and have my phone seamlessly switch between the 2 signals, using whichever is the strongest? Why isn't working to begin with?
Or, is there someway to configure the phone so that it readily switches to whichever SSID has the strongest signal?
If this needs to be posted elsewhere, please suggest where.
Thanks.
So:
Thanks.
