So when charging the lock screen gives you the % and when it is charged it says charged, but if you go into the phone while still plugged in the battery icon in the top right corner still has the lightning bolt like it is still charging, also if you go into the battery stats while plugged in it says 100% charging.
Question is will these ever say charged or not show the lightning bolt when plugged in?
