Verizon Nexus OTA 4.0.4 red triangle exclamation point
Kegman
207
5
I am rooted and have an unlocked bootloader but have stock rom and stock kernals and stock radios.... everything else stock.
I get the "new update available" OTA click to restart and the phone restarts. I get the android with a blue spinning something in his back with the progress bar moving. at about 25% it always changes to the android on his back with a red triangle exclamation point. Nothing happens from here.
I can do a battery pull and get the phone to start fine again.
I've seen these problems in other posts, but theres always something thats not the same as my phone for example the person flashed a rom or kernal. I have not.
any help?
Jet300
312
53
28
Do you have stock recovery or CWM?
I have the same problem. I have CWM .. I assume we need to flash back a stock recovery??
If so... How do I easily do that ? Thanks!
gwhamil
22
I have the same problem under the same circumstances. How do I flash back to standard recovery?
dmmarck
Retired Moderator
Dec 28, 2011
8,349
2,594
There's been a few posts on this scattered about. You need to use fastboot or a toolkit to flash the stock recovery.
Or you could install the OTA manually.
Cigar-Junkie
560
37
I had a similar situation and prior to using this method I renamed the "recovery-from-boot.p" file and removed the .bak extention from the end. I then tried the three step and got the red triangle. After reboot I repeated and all worked this time.
Edit: Using Root Explorer
Reactions: dmmarck
GNex Girl
732
36
That will work if the file has not been deleted and merely renamed with the .bak extension. If the file has been deleted, you have to flash it back.
Jet300
312
53
28
Hmmm.... I just checked using Astro and recovery-from-boot.p is there .. no .bak extension.
I have Nova Launcher installed as a system app from back in the beta days... would that affect the ability to apply the update file and cause the red triangle?
gglassick
dmmarck
Retired Moderator
Dec 28, 2011
8,349
2,594
I used Wug's Galaxy Nexus Root Toolkit. I'm guessing that is stock?
I'm 95% sure that Wug's flashes CWM onto your phone. You need to flash stock recovery back.
To check, power down your phone then hold down volume UP, volume DOWN, and POWER. That gets you to the bootloader. Once in the bootloader, use the volume buttons to make a selection. Find "Recovery," press the power button, and then let me know what you have.
If you have CWM, you need to flash the stock recovery using Wug's or fastboot. There's a bunch of threads floating around re: how to do that.
mozy
131
17
What folder does the stock recovery file go?
samyblaze
