OK... finally got some more time, just right, now... playing around with Groove, Google Voice,, calling back and forth with the wife's phone...
YOU CAN TAKE & Make 4G or WiFi calls.. no one corrected me from Thursday night... Groove works with G-V; so when you port your number over to Google Voice you can make & take calls with your old VZ number..!
This has been the missing piece... G-V really takes our phones to another level... listen to Voice Mails without dialing Voice Mail.. transcribes the VM into text...! fantastic... SMS from the web... etc..!
You can also take calls from Gmail, you can choose which phone to ring, Google Talk (gmail dailer), your Groove, over WiFi or 4G or your old VZ number (regular VZ voice)...
I was worried that I can ONLY forward G-V over to regular Calls and have to use minutes... BUT NO..!! You can take calls with your Google Voice over DATA..! U guys understand... & it will be your NUMBER from before...!
Update:
OK... even cooler, if you exit the Groove IP app, the calls automatically rings your Google Talk (gmail dialer); uncheck the Google Talk, it goes straight to G-V Voice Mail...
I know really confusing... I'm super pumped on dumping VZ for GOOD NOW...!
Update:
