I use Splashtop on my Asus Infinity TF-700 to remotely connect to my PC at the office. When I use Wifi, it works great.
However, whenever I try to tether the tablet to my Galaxy Nexus, Splashtop kills the hotspot connection and I must reboot the tablet and disable/re-enable hotspot on the GN. I am running AOKP 4.2.1 Build 2.
I say it "kills my hotspot" because while tethered before I starting Splashtop my tethered connection on the tablet works great. As soon as I open Splashtop on the tablet, my internet connection on the tablet is killed. Splashtop fails to remotely connect to my PC and no other apps can connect.
I've switching my connection from LTE to 3G and it has no effect. I contacted Splashtop support and they say that my tether probably cannot support the bandwidth, but I responded that I am able to get 7-11 MBPS on the tablet over the tether using LTE, streaming YouTubeHD. They basically have no answers and told me I should try upgrading to Android 4.2.2.
Anyone else here use Splashtop tethered thru your GN? Any ideas?
