1. Dreamliner330's Avatar
    So my Note 2 takes a very long time for the screen to turn on with power button press or after a phone call. This seems to affect all devices. Do custom ROMS resolve this issue?
    If so, which ones?
    03-23-2013 12:30 PM
  2. lpt2569's Avatar
    If so, which ones?
    How long is a very long time? Mine comes on pretty much instantly. I'm running BeansROM build 11.
    03-23-2013 07:14 PM
  3. Dreamliner330's Avatar
    2-3 full seconds. I have yet to hang up on someone, the other caller is always able to hit the end call button before my screen turns on.
    It's really bad on voicemail when I have to wait in silence for the screen to turn on to hang up.
    03-23-2013 08:31 PM
  4. lpt2569's Avatar
    Before you go down the road of unlocking and rooting...any interest in returning it and getting a replacement? Sounds like a defect for sure. Not sure a custom ROM will fix that. Although it probably will.
    Sent from my SCH-I605
    03-23-2013 10:21 PM
  5. jneusch's Avatar
    You could try going into developer options and changing the animation scales to no animation and see if that reduces the delay.
    Sent from my SCH-I925 using Android Central Forums
    lpt2569 likes this.
    03-23-2013 10:33 PM
  6. Lodingi's Avatar
    I agree with the OP. I notice when I move the phone away from my face, there is a delay before the screen lights up. This is annoying when trying to navigate voice prompts. This developer over at XDA seems to be addressing the problem. I'm going to flash it today.
    03-24-2013 08:06 AM
  7. lpt2569's Avatar
    For the record, I'm running BeansROM build 11 and have none of those issues. My wife's Note is stock and has none of those issue either.
    03-24-2013 08:18 AM
  8. fillossofer's Avatar
    I too have a screen on delay and I'm running CleanROM. I have heard of a mod to eliminate it, so I will try to find and flash and report back.
    03-29-2013 06:52 AM
  1. How do I keep the screen on during Google Music play?
    By Donnie Pridemore in forum Verizon Galaxy S III
    Last Post: 10-05-2012, 07:59 AM
  2. Do any of the EI22 ROMs fix the lousy wifi?
    By cluefree in forum Epic 4G Rooting, ROMs, and Hacks
    Last Post: 01-11-2012, 07:46 AM
  3. How do I? Keep the screen "always on" while charging?
    By Satori in forum AT&T Captivate
    Last Post: 03-02-2011, 08:12 AM
  4. Do you notice the screen door effect on your Epic?
    By elguapo76 in forum Sprint Epic 4G
    Last Post: 08-31-2010, 11:37 AM
  5. Do we know what material is the screen on the 4g?
    By ohthebaby in forum HTC EVO 4G
    Last Post: 05-17-2010, 03:48 PM
