1. doncerda's Avatar
    I don't understand why my 4G won't turn on.. I've been to places where I would always get 4G but now nothing... Where can I download new modems or radios because I'm really upset that I don't have 4G on this amazing phone. I am rooted, running AOKP MR1 build 6...
    Baseband version VRALL4... any help would be appreciated. Thanks in advance
    Sent from my SCH-I605 using Android Central No rGForums
    04-06-2013 11:20 PM
  2. MrSmith317's Avatar
    If you got 4G on the same ROM with the same Modems then it's either the service or the phone(hardware). In a known 4G area, try rebooting and see if you pickup 4G. If you can, confirm that you should be getting 4G with another device as well.
    04-09-2013 09:12 AM
  3. doncerda's Avatar
    yeah i tried it today at work... i dont know what is going on.. i have a plan though but we'll see. to this point I Rooted using casual one click method. installed beans v12 and the VRALL4 modem (i think that was the problem since i was on the VRALJB one before i think) and then went to AOKP..... that's when i had no cell service whatsoever.. only 3g data. So my plan is to go back to 100% stock.. reroot using casual (after a day with the stock phone to make sure that stock radio works if not go to verizon with a "stock" Note 2 and see what they say [maybe a new sim is in order]) then if all works flash beans 12 again without changing the modem.. I'll post the results. Thanks for the input
    04-09-2013 05:14 PM
  4. doncerda's Avatar
    My case was causing the issues believe it or not. I HAD the Spigen Snap-on case wallet combo but returned it promptly after I found out it was giving me this issue.
    04-13-2013 01:34 AM
  1. Replies: 28
    Last Post: 09-10-2015, 04:14 AM
  2. 4G But No 3G Connection
    By millerliteboy in forum Droid Bionic
    Last Post: 01-07-2012, 08:30 AM
  3. No 4G connection, live right in the middle of a 4G area.
    By carp00r85 in forum T-Mobile HTC Sensation
    Last Post: 07-01-2011, 06:05 PM
  4. No 3G/4G connection... What gives?
    By fbernar in forum Verizon HTC Thunderbolt
    Last Post: 05-27-2011, 10:18 AM
  5. No Data connection in 4G
    By kcSteve in forum HTC EVO 4G
    Last Post: 12-10-2010, 06:24 PM
