So what are the thoughts on 16 so far?
I haven't flashed it yet, gonna wait till I get home tonight. So far the comments seem to be positive over on the ROM thread.
Just got the notification that there is an update. I have never had a custom ROM with ota updates. Should I flash the new version or just download the ota?
Sent from my SCH-I605 using Tapatalk 2
The multi window control doesn't really work for me anymore, though. I can't add any app to it anymore. Is there a fix to this?
Sent from my SCH-I605 using Android Central Forums
There is a MultiWindowControl App in your app drawer (MWC), you can use this to add apps one at a time.
I'm thinking of installing Jellybean (JB). I'm stock Exynos rooted. First I plan to unlock using the Adam & Relakdev's jailbreak then install Jellybean. After I jailbreak and before flashing JB can I nandroid backup my rooted stock setup so that I can perhaps restore to my rooted stock if want to some time in the future after flashing custom roms like Jellybean? (Maybe as a base configuration between flashing custom roms, or just to have it in case of trouble). Also in the stock state (either before or after the jailbreak) can I back up my apps+data with Titanium and then restore them after I've installed Jellybean?
I just flashed b16, and I was wondering if there was a way to change the battery and the time color from ICS blue to white? I can't post in the XDA forum yet.
Yes, since you are rooted, you can backup your apps with Titanium. Don't backup any system data, this should all get restored through your google account once you reboot after flashing a ROM. Restoring system data from TiBu can cause major issues for your device.
And yes, its always a good idea to keep another ROM (in particular a stock-ish ROM) on your device just in case you need to revert back for some reason.
steps to take:
1. unlock the bootloader
2. backup apps with TiBu
3. flash a custom recovery (TWRP is recommended)
4. flash a custom ROM (follow the instructions from the developer for the ROM on how to flash)
5. restore apps with TiBu once you re-download TiBu from the Play Store (flashing a custom ROM will wipe your phone clean)
I want to flash this but being a noob on flashing roms on the N2, I need to know how to flash this one. Please can anyone tell me step by step on how to flash it. Thanks in advance!
