1. Jonathan Rodriguez3's Avatar
    Rooted, unlocked and running Perseus kernel. Running 4.1.1. How do I update to 4.2.2. Well once it is out for gn2 verizon
    SCH-1605 Note 2
    06-12-2013 12:19 PM
  2. jharo's Avatar
    You'll just flash it. You can get it now if you flash a ROM, but it will be AOSP based not TouchWiz. Really a personal preference there.
    06-12-2013 03:35 PM
  3. Jonathan Rodriguez3's Avatar
    Aosp is better? I've never had
    SCH-1605 Note 2
    06-12-2013 10:22 PM
  4. Jonathan Rodriguez3's Avatar
    Wait i mean i just flash it then I'm good?
    SCH-1605 Note 2
    06-12-2013 10:40 PM
  5. jharo's Avatar
    Yes, you just flash it via custom recovery and your should be good to go. As far as better...it's just personal preference. If you go with AOSP, you'll lose some TW stuff.
    06-13-2013 10:47 AM
  6. Jonathan Rodriguez3's Avatar
    Well since I'm running a different kernel i heard i can brick if i just go ahead and flash
    SCH-1605 Note 2
    06-13-2013 01:23 PM
  7. Trees's Avatar
    Good to be somewhat cautious about mixing kernels and ROMs. What I've found is that by reading the ROM developers web site (on Rootz, XDA, or ROM specific site) that they usually are really good about disclosing what kernels play well with ROMs. I've also noticed that community members are quick to point out issues or potential problems. The developers themselves are typically responsive and want to help, so if you have a specific technical concern then you could always ask.
    06-13-2013 08:28 PM
  1. New to Android phone and need help
    By ntapia82 in forum Samsung Moment
    Last Post: 04-26-2010, 05:40 PM
  2. Android Rookie with the HTC Hero I need help!!!!
    By bigrich34 in forum HTC Hero
    Last Post: 10-14-2009, 12:15 PM
  3. getting started, need help !
    By android for dummy in forum General Help and How To
    Last Post: 09-24-2009, 08:28 AM
  4. Need help regarding my google search bar on my g1
    By wabbit3119 in forum General Help and How To
    Last Post: 09-01-2009, 04:41 PM
  5. need help please
    By jfchica1987 in forum T-Mobile G1
    Last Post: 06-16-2009, 02:12 PM
