1. Jonathan Rodriguez3's Avatar
    I updated a couple of apps from the marketplace aptoide. Now the apps that I updated keep foreclosing how can I reverse the updates or some how fix the foreclose
    SCH-1605 Note 2
    07-25-2013 02:08 PM
  2. Paul627g's Avatar
    I think its safe to say the problem lies in Aptoide and how it goes about providing updates since this is a open sourced app and community.
    Best you can try is going into Settings/Apps/Manage Apps and find the apps in question and see if you are given the option to uninstall the updates. Otherwise you maybe forced into deleting the entire app using Titanium Backup or some other means to get it off the device and start over.
    Just my opinion but best to stick with Google Play Store, Amazon, Get Jar or Slide Me for your application needs.
    07-26-2013 10:51 AM
  1. Samsung Galaxy S3 frozen on start screen... HELP PLEASE!
    By maddiii1991 in forum Samsung Galaxy S3
    Last Post: 01-16-2017, 11:35 AM
  2. Need help switching to Straigh Talk
    By mkdivajenn in forum General Carrier Discussion
    Last Post: 09-09-2013, 01:38 PM
  3. Sd card help
    By Scott Pilgram in forum Sprint Samsung Galaxy S4
    Last Post: 08-08-2013, 10:44 AM
  4. Need Help Using Mobile Hotspot Outside of the Verizon Network
    By MeisterJ89 in forum Verizon Droid DNA
    Last Post: 07-26-2013, 10:32 AM
  5. Help with Video Hub App: update problem
    By six_h in forum Samsung Galaxy SIII I9300
    Last Post: 07-25-2013, 07:16 AM
