1. gathome's Avatar
    I recently bought a Verizon Galaxy Note II running CM 10.1, Android 4.2.2. Under phone status, it seems to be saying I'm roaming and Network is "out of neighborhood." My drop down notification window always says "out of neighborhood" as well. If I check it off, it turns off my data. I'm not sure what this means. Should I be concerned? Is there something I must change in settings to remedy this? Thanks, much!!!
    08-19-2013 09:23 PM
  2. famouzstarz#AC's Avatar
    are you running a nightly or stable version?
    08-21-2013 10:44 AM
  3. gathome's Avatar
    I'm running New versions (Stable only.) It's odd that when I go to my mother's house, about 200 yards away, my phone shows "Verizon Network" and not "out of neighborhood." I have a Verizon network extender in my house as reception here is very poor but my old phones never showed roaming at anytime. Could the extender have any effect on how the phone views roaming areas? Thanks so much for your help!
    08-21-2013 11:33 AM
  4. famouzstarz#AC's Avatar
    the "out of neighborhood" is a CM 10 deal, i did a quick search and your not the only person having issues regarding the roaming issue.
    most individuals have cleared the issue by flashing the newest stable / nightly make sure you do the wipe and all that jazz. hopefully that will clear the issue, i dont believe the network exteneder would be the issue though.
    gathome likes this.
    08-21-2013 11:45 AM
  5. gathome's Avatar
    Thank you! I did call VZW and I'm not incurring roaming charges. I'll take your advice, though, and see if that solves the problem.
    08-21-2013 12:21 PM
  1. Sync of iPhoto albums on the Mac to Nexus 7 - what are the best ways?
    By douglerner in forum Google Nexus 7 Tablet (2013)
    Last Post: 12-06-2013, 10:10 PM
  2. Replies: 82
    Last Post: 08-27-2013, 11:02 PM
  3. Replies: 77
    Last Post: 08-22-2013, 12:17 PM
  4. Third replacement of Droid DNA
    By TheLily in forum Verizon Droid DNA
    Last Post: 08-21-2013, 09:57 PM
  5. Anyone know of a Zune Pass-like music subscription on Android?
    By Justin Young2 in forum General News & Discussion
    Last Post: 08-19-2013, 09:20 PM
