1. Jonathan Rodriguez3's Avatar
    Verizon note 2 sch-i605
    Rooted twrp team win
    Stock rom
    Perseus kernel
    Running 4.1.1
    I want to update the software to 4.3
    How do I do this?
    SCH-i605 Note 2
    08-20-2013 11:52 PM
  2. Golfdriver97's Avatar
    Stock rom
    Perseus kernel
    Running 4.1.1
    How do I do this?
    SCH-i605 Note 2
    Right now, the only way is to flash a custom ROM.
    08-21-2013 12:37 AM
  3. Jonathan Rodriguez3's Avatar
    So any custom rom will work with what I got
    SCH-i605 Note 2
    08-21-2013 03:48 AM
  4. Golfdriver97's Avatar
    SCH-i605 Note 2
    Any custom ROM that was made for your device and carrier.
    Sent from a SlimROM S3.
    08-21-2013 09:06 AM
  5. Jonathan Rodriguez3's Avatar
    Even though I am running a different type of kernel?
    SCH-i605 Note 2
    08-21-2013 06:02 PM
  6. Golfdriver97's Avatar
    SCH-i605 Note 2
    When you flash a new ROM it will install a kernel with it. So no worries there.
    08-21-2013 07:12 PM
  7. Jonathan Rodriguez3's Avatar
    Really? How positive are you bc I've heard I need to find a rom that is able to rub the kernel I'm in now for it to work
    SCH-i605 Note 2
    08-22-2013 12:39 AM
  8. Golfdriver97's Avatar
    SCH-i605 Note 2
    I don't think I have ever seen a ROM that has a kernel separate. There are some with OPTIONAL kernels that are additional, but not separate.
    08-22-2013 01:11 AM
  9. Golfdriver97's Avatar
    Are you looking at going to Cyanogen or AOKP?
    08-22-2013 01:12 AM
  10. Jonathan Rodriguez3's Avatar
    Idk what do you recommend
    SCH-i605 Note 2
    08-22-2013 03:49 AM
  11. Golfdriver97's Avatar
    SCH-i605 Note 2
    AOKP if it is supported. Check their website.
    08-22-2013 05:00 AM
  1. Replies: 4
    Last Post: 05-11-2016, 04:24 AM
  2. Help Rooting 4.1.2 ATT S3
    By Symbianblack in forum AT&T Galaxy S III
    Last Post: 09-11-2013, 04:58 PM
  3. Help! DNA back to stock
    By ternell99 in forum Verizon Droid DNA
    Last Post: 08-21-2013, 04:08 AM
  4. What kind of app do you need in your life?
    By pagosElite in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 08-20-2013, 10:11 PM
  5. I need help with Skype outgoing video.
    By mangurian in forum Samsung Galaxy Note 10.1
    Last Post: 08-20-2013, 10:04 PM
