jharo
I've rooted a number of different phones for myself and my friends, and this has got to be one of the easiest I've ever rooted.
The YouTube review of the note 2 said it would be a sin to root this device and that's coming from a developer
Sent from my ADR6400L using Tapatalk 2
I have to assume the dev is actually referring to putting a custom ROM on it. Because without root, titanium backup doesn't work and access to the command line is limited.
Pool shark is right, rooting wont change the functionality at all just gives you more options. They use the term "Root" very generally
i think you are right. here is the video. the part im talking about is at 9:30
Yeah she is talking about changing the ROM not rooting
Rooting just gives you superuser access, meaning you can change files that you could not before, but the functionality all stays the same
seeing that portion of the segment makes me want the wifi toggle on the bar. Boo.
Did you root yet?
nope I'm too scared to do it. I'll probably wait a little bit. The only thing I would like resolved is removal of bloatware and the wifi toggle on the top
would you like me to do it for you sudbury?
can u help me out to?
Sure as long as you dont mind screen sharing, ill message you on what to do
Hey salem, step off. He offered me you can do it for me???
Im nervous. Haha. Have you removed bloat? How much memory frees up?
