1. SpikeJones's Avatar
    Is anyone here having wi-fi issues?
    When on wi-fi, everything works fine, but it's connecting to a wifi network that I am having problems with. At my school for example, we have a wifi network that I connected to the first day I got my phone. Everything worked okay, and I was happy. When I left for lunch, it of course disconnected. When I came back though, instead of connecting automatically, like it does on any other device, I simply get a notification in the bar saying a "wireless network is available," and that I can select one. I can go into the settings, and click on my school's wifi, but it makes me enter the password again. When I go to enter the password, in the box, it says, "unchanged," and I have the option of just connecting, but it tells me my password is wrong. I typed in the correct password about 5 times, and it kept saying it was incorrect. I tried for a 6th time, and it finally connected.
    The next day when I came to school, it happened again. It would not connect automatically. It would alert me that a network is available, but I have to manually go and select it, and type in the password again and again.
    It's only happening at school (connects to my home wifi just fine), so maybe it's the school's routers' fault? I don't know though, because my iPod and computer are able to connect automatically, as well as my friends' Androids.
    Is anyone else having this issue?
    12-11-2012 10:33 AM
  2. cubetop's Avatar
    Not me. Mine syncs up and connects so fast that I usually don't even notice it. Even when I hit a new area with an open node it jumps right in. I also notice that I have much better WiFi performance than my MAXX did. I get my house WiFi while across the street talking to my neighbor. I am quite impressed with mine.
    corymcnutt and collett like this.
    12-11-2012 11:27 AM
  3. SpikeJones's Avatar
    Hmmm, I guess I will try and go to other places with open wifi and see what happens. Wifi is great, but I just wish it would work likes yours does at my school. Could something be wrong with my phone?
    12-11-2012 12:26 PM
  4. cubetop's Avatar
    I guess it's possible. I know my MAXX didn't like some routers and would slow down or fail to connect. My Note 2 doesn't seem to have that problem.
    Sent from my SCH-I605 using Tapatalk 2
    12-11-2012 02:50 PM
  5. Markster1's Avatar
    It's possible the school is using an older protocol that your phone just doesn't plat well with. Check to see what it is next time, wpa/wpa2, wep or other.
    collett likes this.
    12-11-2012 03:27 PM
  1. Intro plus help w/ bluetooth, fb and wifi issues
    By kerrchdavis in forum Verizon Droid Incredible
    Last Post: 05-09-2010, 03:37 PM
  2. Wifi issues
    By WAM in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 03-06-2010, 06:22 PM
  3. Wifi issue after reset
    By Crowfoot in forum HTC Droid Eris
    Last Post: 03-02-2010, 04:01 PM
  4. Droid Eris WiFi Issue with Mixed Router Signals
    By ridavid81 in forum HTC Droid Eris
    Last Post: 01-02-2010, 10:09 PM
  5. WiFi Issues
    By VDubb22 in forum HTC Hero
    Last Post: 01-02-2010, 02:01 PM
