1. zanshin825's Avatar
    Hi, guys.
    Okay...I'm trying to identify and eliminate a sound that the phone is making at night. I have blocking mode on, and my notifications off...but every once in awhile, I hear some sort of notification noise that's a simple "BeeBoop". Since I have blocking mode on, I have no idea what it is, and it's driving me crazy because it keeps waking me up. When I check the phone, though, there's no message or notification, and when I go into sounds, I don't see what's making the noise. It usually happens between 3 and 6 am, more than once...and I have blocking mode set until 7 am.
    Any ideas? Does it make noises when it reaches full charge? I never notice one during the day, but that's the only think I can think it could possibly be. And, if so, how do I turn that crap off?
    Thanks.
    12-13-2012 08:05 AM
  2. specops2k3's Avatar
    There is a notification sound for full battery I believe
    Sent from my SCH-I605 using Android Central Forums
    12-13-2012 08:14 AM
  3. orgelbau's Avatar
    Yep. Battery is fully charged.
    12-13-2012 09:09 AM
  4. zanshin825's Avatar
    Is there a way to turn that nonsense off? I looked under both Sound, Power and Battery and can't find any way to do it.
    - - - Updated - - -
    Also, it's ridiculous that Blocking Mode doesn't just handle that.
    12-13-2012 09:19 AM
  5. zanshin825's Avatar
    I just did a search for "Battery Charged Silencer" in the market and it says that the app isn't compatible with the Note 2. Man, I need to shut this thing up.
    12-13-2012 10:04 AM
  6. orgelbau's Avatar
    If you mute the system volume does it still give you trouble?
    12-13-2012 10:20 AM
  7. zanshin825's Avatar
    I haven't tried that yet, because I thought that this sort of thing is exactly what Blocking Mode is for. If I mute outright, then I won't get emergency calls from my favorites, which is how I have it set up. Sort of defeats the purpose. But I guess I don't have much of a choice.
    12-13-2012 10:29 AM
  8. zanshin825's Avatar
    Now I'm trying something called "Silent Sleep" which auto-enables mute during a defined period of time. Not a perfect solution, but I hope it works. What a stupid and unnecessary problem.
    12-13-2012 10:37 AM
  9. zanshin825's Avatar
    Scratch that. On second thought I'm going to try this Tasker option that I found on YouTube. I'll post it here in case it helps someone else.
    Tgusnik likes this.
    12-13-2012 11:12 AM
  10. zanshin825's Avatar
    Just charged my phone to 100%, and I can confirm that the Tasker method works, in case anyone was interested.
    Verapakill likes this.
    12-13-2012 01:31 PM
  11. Wildo6882's Avatar
    Is there not a manual shut off? My S3 had it. Can't remember where, but I had it set to not do it because I always charged at night and it was right next to my head. That would drive me INSANE!
    12-13-2012 07:06 PM
  12. zanshin825's Avatar
    If there is, I haven't found it and no one has mentioned it.
    Sent from my SCH-I605 using Tapatalk 2
    12-13-2012 07:08 PM
  13. Wildo6882's Avatar
    Crazy. That's definitely something that shouldn't need a work around.
    12-13-2012 07:43 PM
  14. zanshin825's Avatar
    As an update, I now think that it was the charging sound that was somehow triggered by a Motorola charger that I was using in the bedroom. Maybe it wasn't providing enough juice. I swapped it for the oem charger and haven't had the issue since.
    12-16-2012 08:04 AM
  15. Tgusnik's Avatar
    I have the same experience/sound. However it only occurs if the screen is on. I have the Sprint Variant.
    02-12-2013 03:46 PM
  1. Live Wallpapers (Earth at night with lights?)
    By kpurdu1 in forum Android Apps
    Last Post: 04-25-2011, 09:55 PM
  2. X makes weird sounds at night
    By Arelunde in forum Motorola Droid X
    Last Post: 08-30-2010, 04:36 PM
  3. Replies: 1
    Last Post: 08-09-2010, 10:03 PM
  4. bach file to make phone sleep at night :)
    By lasix in forum HTC Hero Rooting, ROMs, and Hacks
    Last Post: 06-27-2010, 12:37 PM
  5. Live Wallpapers (Earth at night with lights?)
    By kpurdu1 in forum Motorola Droid
    Last Post: 03-31-2010, 09:40 PM
