1. alvarez13's Avatar
    I can't stand the stupid water droplet sound when pressing the screen. Yes I've turned it down in sound, but I want to hear something when I press an icon for feedback. Is there a good way to replace it with the stock JB sound?
    12-17-2012 02:22 PM
  2. MrSmith317's Avatar
    If you're rooted yes, if not probably not. If you're rooted, mount /system as read only and replace the file /system/media/audio/ui/S_HW_Touch.ogg and TW_Touch with whatever sound you want.
    alvarez13 likes this.
    12-17-2012 03:31 PM
  3. alvarez13's Avatar
    Yah, I took my Effect_Tick.ogg off my nexus and renamed it to those 2 files and then added the 2 you mentioned (after backing up the originals and changing .ogg to .bak). It did not work immediately, but after a quick restart I am one happy customer. When I get a system update, will it screw these up again? It's an easy fix, but just curious.
    Maybe I'll spend the rest of my day changing my battery full sound to a burp.ogg =)
    For anyone else who wants to do this, just download root explorer and replace the files previously mentioned and make sure the permissions are the same. Attached is the file I replaced them with from my Galaxy Nexus.
    12-18-2012 10:01 AM
  4. MrSmith317's Avatar
    An update will only mess up those sounds IF they've included the original sounds in the update package. If not, you're good.
    12-18-2012 10:56 AM
  1. Droplet sound keeps being re-enabled...?
    By storino03 in forum Sprint Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 10-04-2012, 04:48 PM
  2. Anyway to change the water droplet sound when making a phone call
    By elvis1935 in forum Sprint Galaxy S III
    Last Post: 07-07-2012, 11:36 PM
  3. Stop the annoying startup sound and video
    By bmann in forum Verizon Droid Charge
    Last Post: 06-08-2012, 07:11 AM
  4. Annoying clicking sound with the Beats by dre solo hd headphones.
    By hournet562 in forum Other OS's and Devices
    Last Post: 06-07-2012, 03:11 AM
  5. Annoying "Droid" notification sound
    By mklotz418 in forum Motorola Droid
    Last Post: 03-16-2010, 10:00 PM
