12-28-2016 04:44 AM
87 1234
tools
  1. Sheldon Clowater's Avatar
    SD card is illuminati
    03-11-2015 03:12 PM
  2. smartdude_ratan's Avatar
    Can i get back my data from sd card
    its showing sd card is blank or has supported file system
    03-18-2015 11:58 PM
  3. Sm29's Avatar
    I did this and it acted like it was going to recover but said the root folder was full and space was needed. Then the computer gave the error that the volume doesn't contain a recognized file system file. Help please!!!
    05-05-2015 09:25 PM
  4. Judith Pavillar's Avatar
    Why my sd card says blank card??
    05-14-2015 05:18 AM
  5. Dubstepgamer60's Avatar
    05-20-2015 01:59 AM
  6. Mark Keen's Avatar
    Hi There all,
    It is generally the simplest answers that most overlook, my wonderful wife S3 GT-I9300 Galaxy Phone had the same issue as most, most instantly think the card isn't blank WTF is going on, the answer is in the second half of this message, unsupported file IN THE system, she had installed an unsupported EPUB book without the reader App on her phone, she converted the epub to pdf which worked for her, but she had left the epub version of the file on the SDCARD, i used an explorer like FILE EXPERT and found the epub and deleted it.
    Then removed the unsupported file and the Notice disappeared after restart.
    Mint, Wife happy, which naturally falls over to myself being happy.
    tragedy avoided, yay!! peace all!
    05-29-2015 06:57 PM
  7. superbabe32's Avatar
    i put my sd card in computer to retrieve photos from my samsing s3 with a recovery company that wanting me to pay and so i took sd card out of computer its now saying format card please help as i dont want to loose my photos
    06-03-2015 03:58 PM
  8. Adi B1's Avatar
    Check to see if the card is not damaged. I got the same message as you all. When I looked closely at the card it was damaged. Not much but enough apparently. I was trying the remove the case to change the sim...
    06-11-2015 03:10 PM
  9. luisbmx7's Avatar
    what explorer did you use i did this before but i cant remember how i did it but i know its a corrupted file. please help
    06-14-2015 10:55 AM
  10. Fatma Mohammed's Avatar
    i did those steps n it`s not working too
    i rest the phone like a 100 time n it still not working
    06-15-2015 02:43 PM
  11. McApril's Avatar
    I've had my Galaxy Ace nearly 18 months with no complaints. Installed new, larger SD card about 5 months ago. Had no issues. Last thing I've installed was Words With Friends over 2 weeks ago.
    Today my phone froze, and after I restarted it, it gave me the topic error message.
    I've restarted at least 5 times, I've made sure the card was inserted correctly, it works in my husband's phone... what the crap is wrong?
    Interesting point: the same thing happened with my last Samsung phone.
    07-13-2015 08:12 PM
  12. Larry Legrand's Avatar
    My problem is that sd card is blank or not suported,and when i inserted it in desktop it is not recognized at all... anyone help?.thanks
    07-15-2015 03:21 AM
  13. Larry Legrand's Avatar
    How do I fix this
    07-15-2015 03:23 AM
  14. Jamal Asim-Music's Avatar
    GOOD INFORMATION! All I did was restart my phone with the card in and everything re-appeared!!! Thank you!
    07-26-2015 09:03 AM
  15. postcd's Avatar
    How to fix this? You need to insert your SD card to the SD card reader and plug the reader into your computer USB port. it should connect as a new drive and copy all data from this drive to your computer. Then format card FAT32, Quick format. Then copy data back and insert SD card to your Android device. If computer cant read the card, and tried various USB ports or various SD card readers, card is probably damaged, and probably only specialised firm may restore some data. .. at least i think so
    07-27-2015 03:30 AM
  16. Kathleen Carlson's Avatar
    08-11-2015 07:35 PM
  17. Yesid Useche's Avatar
    You were right, I did that and it now is recognized by the phone I have a galaxy s5
    thank you
    08-12-2015 10:04 AM
  18. Olutope Olusola's Avatar
    How do I fix this error?
    SD card error "SD card is blank or has unsupported file system... I have a Samsung note 2
    08-13-2015 02:44 PM
  19. Sandy Clark's Avatar
    THIS! This worked when nothing else did for me...I can't post a link but go to www (dot) cardrecovery (dot) com.
    08-22-2015 01:56 PM
  20. ahmed gady's Avatar
    10-06-2015 01:42 PM
  21. andy murshidi's Avatar
    Yepp, finally i just found out how to recover back the SD card to its settings without needed to format it. I tried to connect with USB to PC.
    1. Connect phone to PC
    2. Remove SD card, then insert it back
    3. Insert SD card to your phone
    4. There a screen display on your phone, just click 'YES' (restart MTP device) i think
    5. Just wait.
    6. I've done it already.
    All my data in SD card were not damaged or missing
    You just try it. On my Samsung tablet 7.0
    10-14-2015 07:32 AM
  22. kittenkat22's Avatar
    Can you tell me what you did to rectify this? I am pretty sure my problem was caused like yours. I have tried all the other suggestions here and chkdsk and nothing works. I even used a pay for recovery system and they found nothing. Sad I lost all my vacation pics- I could not backup as we had no WIFI while traveling.
    11-04-2015 01:51 PM
  23. Abid1's Avatar
    Hey please tell us what T Girish suggested you
    11-08-2015 05:28 AM
  24. jdraper2015's Avatar
    Did you end up resolving this issue? I am having the same issue, but am trying to recover all the files I have saved on the card
    11-12-2015 10:57 AM
  25. jdraper2015's Avatar
    he suggested formating the card, however doesnt seem we are able to recover files. I have tried everything and nothing is working.
    11-12-2015 11:24 AM
87 1234
  1. Sd card blank or has unsupported file system
    By Cjclassen88 in forum General Help and How To
    Last Post: 10-14-2015, 07:33 AM
  2. HELP! "SD card is blank or has unsupported filesystem"?!?!
    By jacquimartin1225 in forum New to the Forums? Introduce Yourself Here!
    Last Post: 04-09-2013, 05:08 AM
  3. Why does it say the SD card is blank?
    By nicoles0927 in forum Verizon Droid Incredible 2
    Last Post: 06-13-2011, 08:15 AM
  4. SD Card Error Message
    By MasonMI in forum HTC Droid Eris
    Last Post: 12-29-2010, 01:40 PM
  5. sd card error
    By countrychic84 in forum HTC Hero
    Last Post: 06-10-2010, 03:25 AM
