DroidXcon
This dock is sweet! Was playing gta 3 on my big screen with a ps3 controller! Hooked up a wireless keynoard/mouse combo and everything is plug and play!
Question, where can I find a usb to note 2 mini usb adapter? (For when I want to use the ps3 controller without the dock/big screen)
Sent from my SCH-I605 using Android Central Forums
So after posting about buying one on amazon I decided to try to make my own. It looks like a butcher did it but it works lol. I took an old charging cable and I took apart a wall charge that stopped working a long time ago. I took out the female usb port from the wall charger. I cut off the end of the charging cable and soldered it to the female usb.
Then I took apart the casing on the micro usb side and realized it was encased with silcone so I was going to give up but decided to get this done. So I took the soldering iron and melted through till I hit the pin I wanted to solder. I soldered the wire then did the same on the other side and I was done.
Hooked up my thumb drive and it automatically connected.
From my Galaxy Note 2 via Tapatalk
