1. Phoenix111's Avatar
    What is this sdm causing my phone to stay awake so much?
    Sent from my SCH-I605 using Xparent Green Tapatalk 2
    02-26-2013 03:23 PM
  2. Wobblin30's Avatar
    Are you running power saver mode?
    02-26-2013 03:39 PM
  3. Phoenix111's Avatar
    Nope, it's checked off.
    02-26-2013 03:50 PM
  4. anon(394005)'s Avatar
    I believe SDM is related to OTA updates (see posts below). Not sure why it's causing a problem though; phone trying to frequently check for updates? Did you install the latest OTA (I605VRALL4) recently or still on original stock firmware (I605VRALJB)? To check go to Menu, Settings, About Phone, Build number.
    What is SDM and why is it keeping my phone awake? - Galaxy Nexus - RootzWiki
    http://forums.androidcentral.com/ver...ml#post2529891
    02-26-2013 03:50 PM
  5. Phoenix111's Avatar
    Actually I keep deferring the update because I want to set aside time to root. Do you think it's constantly checking for updates and killing my battery?
    02-26-2013 04:15 PM
  6. anon(394005)'s Avatar
    It does sound like the OTA updater is triggering frequently preventing the phone from going into a deep sleep and subsequently causing increased battery drain.
    02-26-2013 04:28 PM
  7. Phoenix111's Avatar
    Gotcha, thanks for the info
    02-26-2013 04:34 PM
  1. Battery Drains when the power is off..
    By cy8ercop in forum Motorola Droid
    Last Post: 08-21-2010, 09:22 AM
  2. Battery drain
    By Snipperdo17 in forum Motorola Droid
    Last Post: 02-02-2010, 04:43 PM
  3. 2.0.1 battery drain?
    By droidweasel in forum Motorola Droid
    Last Post: 01-19-2010, 07:45 PM
  4. battery drain when device is off?
    By sicario666 in forum Motorola Droid
    Last Post: 01-04-2010, 11:40 PM
  5. My battery drained overnight
    By pbrennan42 in forum General Help and How To
    Last Post: 01-02-2010, 02:30 PM
