1. maryhalltworound's Avatar
    how bad is it to keep Skype running 24/7? will it kill the battery much faster?
    02-27-2013 12:33 AM
  2. MrSmith317's Avatar
    Skype is a battery hog and it's constant pinging will suck up some battery but probably not to the point where you're going to notice too much. I'd say if you get 20 hours out of your battery, leaving skype on 24/7(without any actual voice/video calls) will probably pull 2 hours off of that.
    02-27-2013 07:52 AM
  3. DaRkL3AD3R's Avatar
    MrSmith's probably about spot on.
    Any login session like that where it has to keep hitting the servers to look for incoming messages/calls and to keep you seen as online, is going to take a hefty toll. I only login Skype when I know I am about to make a call. And even in the short time I'm logged in on a video call, my battery drain is substantial.
    02-27-2013 10:16 PM
  1. So I was wondering how easy is it to?
    By trigun123478 in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 05-29-2011, 03:37 PM
  2. NFC chip, how important is it to you?
    By HotIce05 in forum Samsung Galaxy S II
    Last Post: 05-03-2011, 08:18 AM
  3. How easy is it to access the power button?
    By kalldrexx in forum Motorola Droid
    Last Post: 03-05-2011, 12:20 AM
  4. How Hard is it to rollback to stock 2.1???
    By Panthersfan86 in forum Motorola Droid X
    Last Post: 08-21-2010, 05:09 PM
  5. How easy is it to root the droid
    By gotwood3001 in forum HTC Droid Eris
    Last Post: 04-29-2010, 06:43 AM
