1. Solid_Droid's Avatar
    My ? is the battery the same physical size as the one that comes with the Note 2 or is or is it thicker?
    If you know, I'd sure would like to know.
    I coming from the Thunderbolt, which wouldn't last much more than 3 hours, so the Note 2 is great but if I can get more mAH without increasing the size I will.
    02-27-2013 10:07 AM
  2. jlost's Avatar
    I don't think you need to get an extended battery for the note. I have had my phone for a month and noticed it lasted 18hrs with 24% left on moderate use. I always had extended batteries on my other phones so i know. lol
    02-27-2013 10:53 AM
  3. z71kris's Avatar
    thats the main reason I got this phone is to get through a day of regular use, that and its a bad mamajama...
    02-27-2013 11:00 AM
  4. DarkChylde-QC's Avatar
    Nope, definitely not the same size as stock - it humps out.
    02-27-2013 12:18 PM
  5. chuckh0308's Avatar
    I doubt you will need a bigger battery. I came from the Thunderbolt too and the difference is huge. The Note 2 comes with a standard battery that is larger than the extended battery for the T-Bolt, plus it is considerably more efficient. And if you were to need to charge it in the middle of the day, it charges very quickly.
    02-27-2013 12:25 PM
  6. anon(394005)'s Avatar
    I came from the Thunderbolt as well. While the Note 2 gets great battery life in comparison, if you're looking for additional run time I'd highly recommend the Samsung Spare Battery Charger (link and pic below) instead of a third party battery. It comes with another stock 3100mAh battery and also makes a great stand (portrait or landscape) which helped lessened my concern of losing the Thunderbolt kickstand. I believe you can still get 50% off by signing up for a Samsung account.
    Galaxy Note II Spare Battery Charging System: http://forums.androidcentral.com/e?l...token=p03UxLSC
    02-27-2013 01:12 PM
  7. Solid_Droid's Avatar
    Thnx 4 the input. I'll get that spare battery charger and remember how bad Thunderbolt was...
    02-27-2013 06:05 PM
  8. dt81's Avatar
    There is a thread on here about the 4100mah battery that I and others have purchased. Give a look through as I am happy with the purchase. Can go a day or two with out charging and heavy use and it's same size as stock.
    Sent from my SCH-I605 using Android Central Forums
    02-27-2013 08:31 PM
  9. chuckh0308's Avatar
    Admittedly, I haven't used the device a whole lot today, but it has been off the charger for 9.5 hours and it's still at 86%. Made a few phone calls, checked email a few times, FaceBook a few times, and other random things. I have GPS and Bluetooth turned on. The Thunderbolt would have been dead with the same usage.
    02-28-2013 06:51 PM
  1. Innocell 3500mAh Super Extended Life Battery
    By Mobimop in forum Google / Samsung Galaxy Nexus
    Last Post: 07-08-2012, 01:01 PM
  2. Innocell 3500mAh Super Extended Life Battery
    By NHBass39 in forum Thunderbolt Accessories
    Last Post: 07-07-2012, 08:28 PM
  3. Seido Innocell 3300mAh Extended Life Battery
    By topofmurrayhill in forum Epic 4G Accessories
    Last Post: 09-02-2011, 05:24 PM
  4. Innocell 3500mAh Extended Life Battery
    By markyflies in forum HTC Hero
    Last Post: 01-25-2010, 11:55 AM
  5. Innocell 3500mAh Super Extended Life Battery
    By in forum Verizon HTC Thunderbolt
    Last Post: 12-31-1969, 07:00 PM
