1. viper31573's Avatar
    i want to listen to something that says i need adobe but adobe isnt compatible with the note 2. can i download any flash player and will it work?
    03-03-2013 08:42 PM
  2. Greg C's Avatar
    Nothing after Android 4.0 is supported by Adobe. You need to download Boat browser and install the latest version of Adobe Flash. STAY AWAY from other "flash" plugins. Only trust Adobe.
    viper31573 likes this.
    03-03-2013 08:59 PM
  3. Greg C's Avatar
    Galaxy Nexus > Adobe Flash Player Pg 3 > XDA
    Link for Adobe download
    03-03-2013 09:24 PM
  4. Greg C's Avatar
    If you use Boat browser... make sure you enable plugins under page contents of browser settings.
    03-03-2013 09:26 PM
  5. dpham00's Avatar
    I would recommend downloading it directly from Adobe. Just get the one with the highest revision number, that is the latest. Firefox works fine for me. I mainly use it for amazon instant video. Make sure to select the desktop site from whatever browser you are using. Note that not all browsers support flash.
    http://helpx.adobe.com/flash-player/...-versions.html
    Sent from my Verizon Samsung Galaxy Note II
    03-03-2013 09:38 PM
  6. viper31573's Avatar
    got it installed and working. thanks everyone
    03-03-2013 11:27 PM
  7. Sharlene Mae Arizapa's Avatar
    I have gs3 and I want to know if Adobe flash player is downloadable for my phone?
    03-11-2013 09:39 AM
  8. Josphe72's Avatar
    03-11-2013 04:54 PM
  1. Can't get flash player working onTab. 7
    By quicksilver53 in forum Samsung Galaxy Tab 7-inch
    Last Post: 01-20-2013, 03:12 AM
  2. Flash player worked for awhile, then stopped. ???
    By rodya234 in forum Samsung Replenish
    Last Post: 12-04-2011, 06:02 PM
  3. Will any usb cord work with charger?
    By hal1 in forum Verizon HTC Thunderbolt
    Last Post: 04-11-2011, 12:05 PM
  4. Replies: 0
    Last Post: 02-04-2011, 04:12 AM
  5. Flash Player 10 on Android 2.1 (Tablet ZT180) not working?
    By baroim in forum General Help and How To
    Last Post: 01-29-2011, 07:40 PM
