1. Hail6's Avatar
    I got my note 2 right before Christmas. .. battery was awesome until about 2 days ago.... I don't even get 2 hours of screen time and before I'd get 6+ sometimes. .. can someone helo me please!!!
    From my Note2 to hopefully yours
    03-06-2013 02:32 PM
  2. Greg C's Avatar
    Do you have screen brightness on auto or set to a percentage.... auto will drain your battery faster. What programs do you have running in the background? If wifi is on and your not near wifi then your device will constantly look for wifi and that too will drain your. battery.
    03-06-2013 02:54 PM
  3. anon(394005)'s Avatar
    Anything unusual showing under battery use (Menu, Settings, Battery)? Did you happen to install any new apps around the time the increased battery drain started? Any noticeable change in signal strength (poor signal can cause increased battery drain)? Are you using the stock Samsung 3100mAh battery or a third party one (trying to rule out bad battery)? Also, below are a few apps that help troubleshoot what's going on with battery drain:
    CPU Spy:
    https://play.google.com/store/apps/d...valosek.cpuspy
    BetterBatteryStats:
    https://play.google.com/store/apps/d...erystats&hl=en
    GSam Battery Monitor
    https://play.google.com/store/apps/d...m.gsamlabs.bbm
    03-06-2013 03:05 PM
  1. Help me diagnose my battery issue, please.
    By EvilMonkey in forum HTC EVO 4G
    Last Post: 09-01-2011, 08:19 AM
  2. battery life,please help!
    By ydh2323 in forum Motorola Droid 2
    Last Post: 05-16-2011, 02:50 PM
  3. Horrible Battery Issues - Help please!!!
    By marlin29311 in forum Verizon HTC Thunderbolt
    Last Post: 04-18-2011, 06:52 PM
  4. Battery Issue*** Please help
    By sandoff in forum Verizon HTC Thunderbolt
    Last Post: 04-05-2011, 09:21 PM
  5. Battery life suddenly sucks! Help please.
    By droidX1991 in forum Verizon Fascinate
    Last Post: 10-18-2010, 11:17 PM
