1. tekjunkie28's Avatar
    Check out these and help me please
    Sent from my SCH-I605 using Tapatalk 2
    Attached Thumbnails Extreme battery drain when not in use.-uploadfromtaptalk1363390243540.jpg   Extreme battery drain when not in use.-uploadfromtaptalk1363390259634.jpg   Extreme battery drain when not in use.-uploadfromtaptalk1363390269768.jpg   Extreme battery drain when not in use.-uploadfromtaptalk1363390278036.jpg
    03-15-2013 06:31 PM
  2. Wobblin30's Avatar
    Your network and wifi connection look like a problem. A phone constantly trying to connect will suck battery like no other. Spotty coverage in your area?
    Sent from my SCH-I605 using Android Central Forums
    03-15-2013 08:37 PM
  3. tekjunkie28's Avatar
    Nope bot at all I have full to 4 bars at home and work. That steep drain was it just setting on my desk while I took a nap and wifi was off then.
    Im not sure why my signsl lines are black but I have had that issue in all 3 samsung phones I had (nexus, s3, note 2)
    03-15-2013 08:58 PM
  4. Bond32's Avatar
    Try factory resetting if you don't mind setting everything up. Also try gsam battery as it can show you which apps are draining more than others.
    03-15-2013 10:55 PM
  5. tekjunkie28's Avatar
    Yea looks like it was just tweetcaster sucking cpu.
    03-16-2013 05:33 PM
  6. tekjunkie28's Avatar
    Is this good battery lifr for the note 2?
    03-16-2013 09:46 PM
  7. kgk1985's Avatar
    Go into settings and make sure wifi stays on during sleep
    sent from Galaxy Note 2
    03-18-2013 04:17 PM
  8. tekjunkie28's Avatar
    Stays on? I have always heard that until recently.
    03-18-2013 08:42 PM
  9. tekjunkie28's Avatar
    Bump
    03-19-2013 05:48 PM
  1. Why "Gallery" using 15% of Battery when not in use?
    By SHIVA77 in forum Verizon Galaxy Note 2
    Last Post: 02-26-2013, 08:12 PM
  2. Battery life best... when not in use. ;-)
    By hannsoft in forum Verizon Droid DNA
    Last Post: 12-08-2012, 07:41 AM
  3. Why is there so much battery drain when not in Use?
    By XChrisX in forum AT&T Galaxy S III
    Last Post: 07-18-2012, 11:59 PM
  4. do you leave your TP on when not in use?
    By jackmei2 in forum ASUS EeePad Transformer Prime
    Last Post: 03-07-2012, 10:24 PM
  5. Moment screen won't lock when not in use
    By ewells1014 in forum Samsung Moment
    Last Post: 10-16-2010, 04:56 PM
