1. Frozenicy's Avatar
    Is the Verizon Note 2 model N7100 or SCH-I605?
    Anyone know the answer?
    03-24-2013 02:51 PM
  2. ferndog75's Avatar
    It's the SCH - I605. If you go on your phone, Settings-About Phone, you will see on Model Number.
    03-24-2013 03:32 PM
  3. taylorz_412's Avatar
    This
    Sent from my SCH-I605 using Tapatalk 2
    03-24-2013 03:32 PM
  4. dpham00's Avatar
    It is also on the name tag under the battery
    03-24-2013 03:33 PM
  5. Frozenicy's Avatar
    Oh ok Thanks guys. Another question, anyone know if Verizon Note 2 support WCDMA, CDMA2000 or TD-SCDMA?
    03-24-2013 03:54 PM
  6. taylorz_412's Avatar
    Not that I can see http://www.phonearena.com/phones/Sam...Verizon_id7494
    03-24-2013 04:12 PM
  7. kgk1985's Avatar
    N7100 is the international model right
    sent from Galaxy Note 2
    03-24-2013 05:01 PM
  8. taylorz_412's Avatar
    correct
    03-24-2013 05:04 PM
  9. Frozenicy's Avatar
    Thanks for the quick replay talyorz, but i found another website call phone scoop said different. Source: Samsung Galaxy Note II (Verizon) Specs, Features (Phone Scoop) Anyone know which website is more reliable?
    03-24-2013 05:12 PM
  10. taylorz_412's Avatar
    I know phone arena is pretty reliable, that's where I go to for complete spec sheets... But they could have it wrong
    03-24-2013 05:15 PM
  11. Frozenicy's Avatar
    Oh i see, thanks for the help.
    03-24-2013 09:10 PM
  12. dpham00's Avatar
    Of course the Verizon Note II has to support CDMA2000, since it has 1xRTT and 1xEVDO, both of which are CDMA2000. According to the FCC filing, it also supports WCDMA, based on the chart below.
    Verizon lists it as being global ready, so for sure it has to be quad band gsm.
    Attached Thumbnails Is the Verizon Note 2 model N7100 or SCH-I605?-verizon-galaxy-note-2-simultaneous-transmissions.jpg
    03-25-2013 08:59 AM
  13. Frozenicy's Avatar
    Ah nice, thanks for the information. Thanks a lot.
    I read somewhere said it support EDGE network, is that true?
    03-25-2013 01:12 PM
  14. dpham00's Avatar
    It does support edge data(see attachment in my previous post) , but you would have to root to change the apn.
    Sent from my Verizon Samsung Galaxy Note II
    03-25-2013 01:16 PM
  15. Frozenicy's Avatar
    Sweet, thank you.
    So as long as I make sure the phone support the foreign country's network, then root the phone, and change to correct apn setting, then I should be able to make/receive calls or texts, and use it's data correct?
    03-25-2013 07:57 PM
  16. dpham00's Avatar
    Sweet, thank you.
    Yup.
    03-25-2013 09:14 PM
  17. Frozenicy's Avatar
    Nice, now I just need wait until the renew date now.
    03-25-2013 09:32 PM
  1. Is the Optimus S screen glass or plastic?
    By droidfool in forum LG Optimus S
    Last Post: 06-10-2014, 04:30 PM
  2. Is the unlocked Note 2 3G or 4G?
    By FreakyLocz14 in forum Samsung Galaxy Note 2
    Last Post: 12-31-2012, 01:12 AM
  3. Is the samsung NOTE coming to verizon?
    By executiveg in forum Verizon
    Last Post: 04-03-2012, 10:07 PM
  4. is the invisible keyboard feature new or am i late to this ball game
    By quixoticelixer in forum Google / HTC Nexus One
    Last Post: 07-01-2010, 10:34 PM
  5. The REAL Nexus 1 is the Verizon version
    By matrix2004 in forum Google / HTC Nexus One
    Last Post: 01-14-2010, 12:19 PM
