04-05-2013 12:48 PM
33 12
tools
  1. dt81's Avatar
    I thought I would post this in here so I can get just note 2 users feedback. I would like to get a car mount for my device but not sure which one is a good one. So do any of you use a mount? If so which one? I'd like to have it mount to the dashboard and extendttowards me while driving. Or have it mount to maybe the center console.
    Thank guys
    Sent from my SCH-I605 using Android Central Forums
    03-27-2013 09:21 PM
  2. dmarcus48's Avatar
    I'm using a brand called iottie, there are a couple of models, the best is about $25 on Amazon, I used it for my iPhone 4 and it fits my Samsung S3. Suction cup on the windshield really sticks.
    Sent from my SCH-I535 using Android Central Forums
    03-27-2013 09:27 PM
  3. dmarcus48's Avatar
    Don't know if it'll fit the note 2 though.
    03-27-2013 09:28 PM
  4. Markster1's Avatar
    https://m.bedbathandbeyond.com/bedba...romSearch=true
    I have one of these and it works great, holds anything.
    03-27-2013 09:59 PM
  5. gospodinjuha's Avatar
    I use this for the Note2 with a Seido kickstand case. It works great!
    Sent from my SCH-I605 using Tapatalk 2
    03-28-2013 12:11 AM
  6. jb81868's Avatar
    I'm using a Travelocity gooseneck mount that plugs into your lighter and has two usb on it to use got it at big lots for ten dollars
    03-28-2013 03:47 AM
  7. chuckh0308's Avatar
    I use a ProClip base mount that attaches to my car and then have a SlipGrip phone holder that attaches to the ProClip base. Same setup I had for my Thunderbolt and wouldn't have it any other way. It's not a cheap combo, but it's solid, holds the phone securely, is easy to use, and it looks good.
    Device Holders and Dashboard Vehicle Mounts-ProClip Car Mounts for Mobile Phones, Tablet, and Handheld Devices
    Galaxy Note II N7100 A993
    Attached Thumbnails Anyone using a car mount for their device? And which one?-20130301_011446.jpg   Anyone using a car mount for their device? And which one?-20130228_200857.jpg
    03-28-2013 03:48 AM
  8. D07's Avatar
    I too have iottie one touch car mount for the note 2. I got it from Amazon and i love it. Fits perfectly.
    03-28-2013 07:08 AM
  9. jneusch's Avatar
    I use the iBolt and it is incredibly secure.
    03-28-2013 07:33 AM
  10. lpt2569's Avatar
    +1 for the iOttie
    03-28-2013 08:01 AM
  11. MikeLip's Avatar
    This. And yeah, getting it OFF the windshield is the trick! It's a nice mount and it's cheap.Reasonably anyway.
    03-28-2013 08:35 AM
  12. MaxBuck's Avatar
    I'm using the Samsung mount, which works fine.
    03-28-2013 10:02 AM
  13. thehikingdude's Avatar
    +1
    03-28-2013 01:33 PM
  14. GregMargie's Avatar
    I too am looking for a decent and reasonable priced car mount. I found the one mentioned above (iottie) on Amazon for $19.99.....looks like it has decent reviews. here's the link
    Amazon.com: iOttie One-Touch windshield and dashboard car mount for Galaxy Note 2: Cell Phones & Accessories
    This one looks really Cool too!
    Amazon.com: Koomus Dashboard Windshield iPhone Car Mount Holder for iPhone 5 4S 4 3GS iPod Touch Samsung Galaxy S3 S4 Note 2 Google Droid GPS Smartphone car mount in White: Cell Phones & Accessories
    03-28-2013 01:40 PM
  15. lpt2569's Avatar
    I've been using this one for a couple months now. It works really well, very secure attachment to the windshield. Definitely worth $20.
    Maybe it's just mine, and others are not like this. I don't like that the arm grabs the device right near (just below) the power button, occasionally blocking the lower portion of the power button...just a minor irritation.
    03-28-2013 02:12 PM
  16. GregMargie's Avatar
    I just ordered the Koomus one from Amazon (second Link I posted)......it had really great reviews and I like the minimal-istic style of it!
    03-28-2013 02:41 PM
  17. NRA_Bear's Avatar
    I went with the iBolt xProDock coupled with the AMPS adapter plate and ProClip vehicle specific mount. I hate having devices in my line of sight, so it's nice to get everything down below the top of the dashboard. I also like that the dock puts the phone into Samsung's dock mode. I just bought everything so the verdict is still out on how well it works in the long run.
    03-29-2013 04:06 PM
  18. Markster1's Avatar
    Found out Android Central carries this for 30 bucks, at BB&Beyond for 11. Quite the price difference!
    03-29-2013 05:40 PM
  19. rabernet's Avatar
    Me as well....
    03-29-2013 10:13 PM
  20. k9cop's Avatar
    Thank you. I have been wondering if this thing was a fluke.
    03-30-2013 12:02 AM
  21. Markster1's Avatar
    You do know the bottom arms adjust up and down right?
    lpt2569 likes this.
    03-30-2013 12:27 PM
  22. tonyfu's Avatar
    Look up Oso grip EX. Very clean and modern design. Looks great on dash.
    03-30-2013 12:54 PM
  23. lpt2569's Avatar
    Edit...Doh! I keep the bottom arms extended down in contact with my dash for more stability. But I could adjust them up you're right.
    03-31-2013 12:18 PM
  24. kgk1985's Avatar
    I have a cheap $8 one from China. Got it on eBay before name brand ones were out. Works great. Clips in place perfectly
    sent from Galaxy Note 2
    03-31-2013 01:02 PM
  25. K_Daddy's Avatar
    http://www.amazon.com/dp/B007FH716W/...cUvbUpU2676516
    This is the one I use. Works great.
    03-31-2013 02:50 PM
33 12
  1. Replies: 3
    Last Post: 12-22-2013, 01:42 AM
  2. Universal car mount for use with TPU (or other) case?
    By h4ldol in forum Epic 4G Touch Accessories
    Last Post: 12-15-2011, 04:07 PM
  3. Who is getting a 32 gb card for their Evo3d and which one?
    By MannyZ28 in forum HTC EVO 3D Accessories
    Last Post: 08-16-2011, 12:43 AM
  4. Replies: 51
    Last Post: 06-19-2011, 12:29 AM
  5. Cheap Car Mount for Use with Garmin Friction Mount
    By pearlmikejam in forum Motorola Droid
    Last Post: 12-29-2009, 11:15 AM
