1. isabellemommy's Avatar
    I bought the Galaxy Note 2 and paired it with the Motorola Elite Sliver I already had. Now I have complaints that everyone can hear horrible background noise when I use the headset. It never did that with my Motorola Electrify. Any ideas? Suggestions? If not, what headset works well with GN2? P.S. I do all calls with a headset so it is important it work and not cost me an arm and a leg.
    04-03-2013 11:54 AM
  2. Big Dawg's Avatar
    I'm having the same problem also if you find out anything before I do contact me
    04-08-2013 12:25 AM
  3. DanW1962's Avatar
    The problem is with Android! I just dumped my HTC One + because the bluetooth sound quality on phone calls was HORRENDOUS. Nobody, HTC, Motorola, or AT&T is recognizing this as a problem. I live by my bluetooth and if they can't get that right I had no choice. I even swapped out a Plantronics for Motorola Elite and had the same problem. I synced with BB Z10 and crystal clear.
    04-12-2013 05:58 PM
  4. radgatt's Avatar
    I had the same bluetooth when I had my nexus. I didn't have any problems with it. Did you try to get a replacement? Maybe the one you have is just defective. If you tried a replacement and still have the same issues I would suggest the blue ant q2. It's $30 cheaper (at least in my area) than the elite silver. I have no problems with that bluetooth. There is also an app in Google play that is compatible with the bluetooth that reads your text messages out loud.
    Sent from my VZW Note 2 using Android Central Forums
    04-13-2013 12:56 PM
  1. Bluetooth issues with your car?
    By slbelt in forum Verizon Droid Charge
    Last Post: 09-26-2016, 11:29 AM
  2. Bluetooth issue with Navigation
    By davidlnewman in forum Verizon Galaxy S III
    Last Post: 10-11-2012, 01:16 PM
  3. Streaming Bluetooth Issues with ICS
    By drdeath91 in forum Droid RAZR MAXX
    Last Post: 07-13-2012, 02:56 PM
  4. Bluetooth issue with streaming
    By mweathers in forum Virgin Mobile Optimus V
    Last Post: 04-12-2012, 04:46 PM
  5. bluetooth issues with jabra bt8040
    By rsbenedict in forum HTC Hero
    Last Post: 11-07-2009, 06:10 PM
